I installed a square smartcraft system monitor gauge.
Fuel burn with 2 people/full tank and gear (raft, survival suits, fishing gear, 125lbs of ice) 4600rpm is 9gph @ 30/31mph. 4600 is the happy cruise in light chop. In slop it does nice 3800/4000 = 24/25 mph roughly 6.5gph. At low speeds this engine is more efficient than the 2.4L 175. I'm super happy. This is perfect for my needs. If I had to carry bigger loads regularly or wanted more speed, then I would suggest a bigger engine. |
Great numbers but 6.5mpg doesnt seem possible. Maybe 3.2mpg?
https://www.mercurymarine.com/en/us/...units=imperial |
thanks CB - that was a typo. 6.5 GPH is what is should be . . . made the correction. fuel burn and speed is nearly identical to the sailfish 220 pdf.
I am thrilled your set up works as expected. Nice package all around for simplicity, affordability, economy and performance. I would expect that your engine rigged out the door is 50% of what a 250hp Yamaha repower would cost.
![]() Quote:
Bigshrimpin-
Hi. Sent you a PM as a followup to an old discussion. Thanks |
Terry - pm replied . . . Sent you 2 messages
Tried a powertech 15P four blade OFS and lost 3.5 - 4mph on the top end . . . could only turn 5250rpm @ 35.5mph. 15p enertia is WAY better. Terry the 17P is packaged up and will go out tomorrow.
Bump for update and thoughts now that you have more hours on it. Any regrets or anything that you would do differently?
Thanks for sharing. |
132 hours on the motor so far. I regret driving from Onset to Chatham and back (in 25+ knot wsw wind) and leaving 10 minutes before the bite turned on. I took a beating coming home across nantucket sound. I also towed a guy from Squibnocket to Quicks Hole (who didn't have seatow) had to cancel dinner reservations. The engine has been awesome and exceeded all my expectations.
