I just purchased this boat and here are some restore pictures along the way with the finished product. I am interested to see if anyone has used or knows where to get the correct spray rails made for this 1973 23 potter hull seacraft. Thanks, Baitrunner
I love that gray color! Looks like its military or customs or something tough.
Don't need spray rails on a 23'
I've asked this question before and gotten the same answers. My boat is as wet as it gets. It's a 1998 hull so I don't know if somewhere along the line the shape of the mold was changed. Mine doesn't seem to have a very sharp edge on the chine at the bow. Their isn't much of a chine at the bow at all. It allows the water to slide right up the hull. Your boat looks great by the way.
![]() Quote:
Fuel Tank Size/Position and Hull Weight are very different when comparing Tracker and CSY to the Potter Hulls. Outboard versions of the Potter 23sf hulls have a smaller 100 gallon tanks positioned directly under the console and seat. CSY and Tracker hulls have 144 gallon tanks pushed to the front edge of the step up. This is 3+ft forward from the position of the potter tanks. Tracker and CSY hulls are several hundred pounds heavier (listed at 2800lbs - CSY and 3070lbs for 1998 tracker 23sf) compared to the potter hulls (listed at 2650lbs dry). The extra weight (from the larger 144gallon fuel tank and thicker hull) pushed forward messes with the strake design in the bow. When the tracker hulls are in rough water I swear that strake gets burried and shoots water up rather than knocking it down. ![]() ![]() |
See the strake in this picture.
1. Add 420lbs to the original hull (1973 hull weight (2650 lbs) vs 1998 hull weight (3070 lbs) 2. Add 277lbs for the extra fuel (44 x 6.3) 3. Shift the 907lbs (144gallon x 6.3lbs per gallon = 907lbs) of fuel 3+ft forward 4. Use a little trim tab in rough seas _____________________________________________ you've got yourself a WET 23. ![]() |
Not exactly to scale, but you get the idea.
Looks like when R+R rebuilt this 1973 23 seacraft, the size (145gallon replacement tank - 2013 rebuild thread) and location of the fuel tank is very similar to the newer style CSY and Tracker boats. 400lbs of rods holders doesn't help either : ) . . . just kidding. Maybe you would benefit by adding some spray rails. I'm assuming it's somewhat of a wet ride now otherwise you wouldn't be asking about rails???
http://www.thehulltruth.com/boating-...r-r-conch.html |
