Old 10-04-2017, 09:49 AM
Right around 400lbs (+/-) seems to be about the max weight (25" transom) without major modifications and weight shifting. Add a bracket to the 20 and the LCG gets all out of whack, so you end up having to move weight forward (batteries/fuel tank/ballast).
Old 10-05-2017, 10:33 AM
Default Weight and CG Effects
Bigshripmpin & others-
Hey Tim- You usually are a good voice of reason on CSC. I wanted to alert you to this in case you had not seen it From time to time I try to tell folks of my post on "estimating CG shift with heavy engines". I put together an example of a relatively simple way to estimate the shift in CG due to heavier engines, outboard brackets, etc. If one were to use this when a change is contemplated then they can actually test the results with water filled coolers or weights before spending money and modifying their SeaCcrafts. Try searching on "estimating cg" Post#1 on page 3 of 3, dated 9-24-16.
