Old 03-03-2018, 09:35 AM
CoreyTrx CoreyTrx is offline
You could pour foam in those stringers. Then just cut flush and wrap glass over the top. A lot easy and quicker than trying to cut wood or foam sheets to fit.
Old 03-03-2018, 09:48 AM
I'm with Corey. Those stringers look to be in great shape, if you wanted after you fill with foam you could wrap a couple of layers of 1708 around them and tie them to the hull for even more strength. That's called "overkill" which is good.
Old 05-16-2018, 10:51 AM
caper caper is offline
Suweet !!
Old 03-06-2019, 07:39 PM
RoomToMove RoomToMove is offline
Can anyone recommend a tank builder? Was trying to use SP Tanks out of New Jersey but apparently their custom tank operation indefinitely closed last week.
Would prefer a builder from the NE but would consider shipping from Florida. Trying to get prepared for the spring.
Old 03-06-2019, 09:16 PM
I believe that there are two aluminum fabricators up there. One has two names, like SP/Speedy Tanks. Almost used him once. IIRC, the other was in Bayville, Route 9.?. Been a long time. Sunshine, and RDS Aluminum if you can draw what you want (not being local).
RDS has built between 8 and 10 Jersey Speed Skiffs, including my brothers. A custom 18 gal. under rear thwart of a BW 15 Sport.
I believe Sunshine may have specs to early SeaCrafts.
Vezo, Part II
Old 03-11-2019, 06:42 PM
ricknewman ricknewman is offline
Atlantic Coastal Welding in Jersey.800 434 8265. They are buildind mine now.
Old 03-12-2019, 08:22 AM
Billybob Billybob is offline
Luther's welding in Rhody.
Old 03-15-2019, 07:11 PM
Thanks for the input. Turns out the place with two names is Atlantic Coastal Weldnig/Speedy tanks. I have quotes out to Speedys and Patriot Marine Fabrication in New jersey. Waiting on a quote from Luther's.
Cheers
Old 03-16-2019, 01:15 PM
Does my mind still remember they are in Bayville, NJ? I was recently taken over a 70 gallon build. Paid $1284. The $84 was Fla. Sales tax when I don’t live there. Tariffs on metal or not, the old adage “$10/gallon” still rings true. Interested in your quotes. Mine was constructed of .125 aluminum, three baffles, fill, pick up, vent and sending unit. Coal tar epoxied. Let us know.
Part II
Old 06-16-2019, 05:20 PM
Vez- haven't been on on a while. Yes they are in Bayville, there are actually a couple companies around Barnegat Bay, all the NJ guys quoted around $750. I walked out of Speedy's for around $850 for a 52gal tank with couple extra items for installing. Not cheap! The Rhode Island outfit seemed very knowledgeable but the quote started at 850 and they do not epoxy coat.
