Thanks Sandy..I'll check that out.
I second this^ the 80's model hulls were a tad longer, not sure where? but they did end up stretched out just a tad.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
Bingo....
Current 2000’s 21 is a cut down 23SF. Over half of the references to a SC 21 currently come from someone rounding the length over 20 on a 20SF to 21.
Snookerd |
![]() Quote:
Now for another question since you've brought up the newer 21...I've talked to several people about the newer 21's being a cut down version of the 23. Yes you can see thats it's way bigger then the 20sf. The question I had was...how was the mold made on the 21? did they simply cut 2 feet off the back of a 23 and make a new mold from that? or has the gunnel height been taken down a bit as well. Anyone ever get a picture of the newer 21 and the 23 side by side? I realize that the interior was changed significantly and would rather not get into that. strick
The beam on the 21 is 8' and 24" of freeboard aft, the 23 is 8 2" not sure of freeboard but I would assume its also more, sitting in the water the 23 is taller
![]() Quote:
Snookerd |
![]() Quote:
Schhhhhnnnnooookems is right. Some folks selling their 20`s called them 21`s. Always heard the newer 21 was a cut down 23. Never taped one. |
My ‘77 Seafari says 19’ 8”, as does my ‘79 MA I believe but can’t put hands on reg right now. After all the title work for the ‘76 Seafari, I also believe to be same.
Vezo |
Gota '83 MA here now, ill throw a tape on it...
NoBone's 1970 birth certificate says 19'6"....
See ya, Ken © |
