Gotta be for fuel tank anchoring i would think...?
I opened the top of one of stringers to see how easy the wood would come out with the plan being to foam the stringers back in, the wood isn't really budging. Without chiseling it out, or opening the stingers from the side, it would be pretty difficult to get the wood out. There is a significant void in the stringer as they are much wider than the original wood. I could foam that in?
Or like I said, I could cut open the stringers from the side as I did the one and get the wood out? |
![]() Quote:
My 21 had wood stringers...they were mostly gone. The wood is only used to form the fiberglass mat...the fiber glass mat is the strength . All I did is remove some of the wet wood, closed up the stringer and applied more fiberglass mat over the top. When they used foam same thing. The foam really has no strength it was used to form the stringer.
Makes sense. I just wanted to be sure I didn’t leave something that is going to eventually make things troublesome from the inside out if I can help it. Getting the wood out was pretty easy from the side once I saw it from the grinding. Getting it out from the top proves to be much harder.
I ran an inspection camera around in the stringers beside the wood and they all look decent. As I mentioned the wood I DID run across exposed was wet so it came out in the big slices you see in the pictures. Raising the height of the stringers is really what I am after to get back to the deck height. Before I took the foam board out, it was raised 3 inches or so. No liner in my boat so I can really go back at almost any height. Original plan before the wood was Coosa on top of the stringers and glass it all in. Others had mentioned maybe easier just building forms around the stringers and using a 4 or 8 lb foam to bring everything to final height. Trying to make decisions before ordering what I need. Thanks so much for everyone’s insight. |
![]() Quote:
So I was kinda on the right track thinking it was a backer for the glass or a former. That was the only thing I could figure as I have used melamine board pieces to back form or press lay ups to get a nicer finish. Sometimes to hold the glass in place especially if overhead. I normally wax the melamine so I can pull if off when done but Moesly just used 1x4"s and left them there. Doubt they had melamine or Formica back then.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
![]() Quote:
They had formica then. Carl used it on the race boat mold. |
If that woods a major pain to get out from the top (sounds like it) i would just leave it. It's been in there that long yano...
I definitely wouldnt be slicing the sides of the stringers to get it out. The juice just aint worth the squeeze on that one! |
Even the melamine needs some kinda release on it, the foam will stick to it somewhat. I would just foam em factory height, then add your raising material and glass over. Thats alot of form work to try and get all even.
