![]() Quote:
Hi HatTrick,
Sorry for the delayed response... I have the batteries mounted forward under the CC seat. I glassed in a piece of marine plywood that spans the width of the console, anchored battery boxes there along with the breaker and the on board charger. The starting battery is up there too. The nose on my '73 isn't as clean as yours is. I have a permanent bow light forward of the puck. I pulled off the starboard cleat to allow for the mount of the quick release bracket. It's the one that just leaves a small rectangular puck on the deck when the motor is off. I've always intended on installing pop up cleats set back a bit but, for now, I just come in port side to.😏 The old Riptide you see in the pic requires months of strength training to deploy but comes up easily. We have a newer Terrova on a Javelin that is a piece of cake to deploy. We fish in some decent chop up here in Minnesota and never really felt I was hanging out over the bow bringing the motor back in.
Temerity => 1973 20' CC Jitters => 13' Whaler At Large on Lake Superior |
The story of my final choice of TM and battery system (a little long winded).
I got a Minn Kota riptide auto deploy Ulterra with spot lock, 36v, 60-inch shaft. Took me a year to make my choice - I spoke to 4 guys with TM on SC 20’s. Two had MK Ulterra’s 24v, 60-inch shafts who were happy with both the power and shaft length. The other two guys who fish the same area I do (long island sound and CT rivers which can have some wicked rips currents) have MK 36v, 60-inch shaft, who recommended to get the 36v if possible (but 24v will hold most of the time). All four guys said 60-inch shafts are fine, if the prop is coming out of the water you probably will not want to stay out for long any way! I had already decided to go with a Lithium battery set up for space, weight. The fore deck on my year SC 20 has an awkward sized fore deck which prevents getting close to a TM mounted at the front on the boats center line (best position if possible) - which makes an auto deploy TM a no brainer for a 68-year-old over a manual TM. Being able to auto deploy the TM while being at the console controls and FF is very nice when close to rocks, makes moving to different spots easier. After using it, I am very happy I chose an auto deploy TM. I have the Iconic 36v 50 AH battery, their dual 36v /12v charger and their 36v heavy duty aluminum battery tray which totaled around $2000. So far so good - The single battery 36v battery is a very clean uncluttered installation - compared to (3) lead acid battery saves 100lb of (2) battery weight and space. A game changer for a SC 20. My single 36v battery install was the first for my marine mechanic (who is truly a master craftsman) - he was not overly enthusiastic when I told him I was going with a new-fangled single "lightweight 45lb" 36v battery but after the "simple" install he was impressed and thinks that is the way to go now. Another feature I really like about the Iconic battery is that it has blue tooth that connects to a app on my smart phone which allow me to easily check the charging status of the battery. On my SC 20 I roughly estimate I will get around 20 hours + - of constant 36v TM use in 5 knot current. Most times I have used 10 - 20 % battery for up to 6-hour fishing trip but not operating the TM all the time - rough guideline. The smart blue tooth app to easily monitor battery usage is nice 2 thumbs up right now |
One day my 23' will go away and I'll have a 20' MA and that similar TM setup. That's very nice!
Thanks for the up date..it sounds like a great combo..
36v 112lbs 60” shaft…
Do not get auto deploy, the linear drive units fail at a pretty Regular rate. Use a 36v lithium battery - Dakota has the best available. Lithium batteries are the way to go - you’re using wet cells costing approx $150 each, need 3,thats $450 you’re gonna need a 3 bank charger along with a plug for it - you’re looking at $275/$300 for the quality brands.that’s about $750/$800. Depending on use, you’re gonna kill those batteries quick,maybe 2 seasons, then another $500 for batteries… Lithium - yes the initial expense is greater , but, most offer 10/12yrs warranty on that battery. Do the math 3’battwriea take up some room, one 36v doesn’t …. I’ve got the unit I mentioned - always go for a heavier unit ! Yep, the 80lbs will work, but get in heavy current and try to hold structure… Use a heavy duty “quick release” bracket - use the rubber bushing that come with the motor under the “puck”,when mounting it. The heading sensor will need to be connected to 12v and fused correctly. Plugs - the cheap “twist” style will not hold up. Junction blocks are not a bad idea, to avoid the common plug corrosion. Attach and heat shrink seal the connectors on the trolling motor power cord , attach these to the junction blocks below the foredeck. Easy enough to undo, when you want to remove the trolling motor. You need to power the trolling motor correctly, do not use a small guage wire for power and ground - the volt drop will be a factor and the amp carrying will to. Use 6g marine grade tinned thru out . “Jump” wires to series the batteries, and power to 70a breaker. Use a quality breaker, not the cheap ones. Run your cabling in a chafe resistant weave - see attached pics. Owner of this rig - he opted for orbital batteries,long wait for lithium he wanted to fish. Note the pic of the cheap breaker ? This boat was factory rigged for a trolling motor. The rigging wasn’t used ! Boat was 2020 and the connectors were not heat shrink sealed, the cabling wicked moisture and the cheap automotive cabling was corrode internally. That breaker in the picture, it was in the bilge,midship.those breakers fail on a regular basis.use a quality breaker,sized accordingly. A good corrosion inhibiting spray is recommended , I like ans use merc corrosion guard, on all connections. Trolling motors require “clean” voltage and amperage - the system needs to be done correctly , for best operation … The “jump” cabling - its color coded, this avoids confusion when redoing connections.remember, batteries are “series” connected, to increase voltage
do not let common sense get in your way |
Let me add a little more here :
I have a Hydrasport , been fishing that till I’ve got my 20 done … I added a 36v 112lbs I pilot to it. I left a few things out , like the head support , you want one of these, it supports the unit when it’s not deployed. Get it ! Be sure and fuse the heading sensor - I’ve lost count of the I pilots I’ve seen with the heading sensor infused and in the wrong location. The heading sensor needs a clear view of the motor to operate correctly . Can’t stress this enough - I’ve seen more problems with trolling motors due to poor wiring and connections … Do it once, do it the right way and be done with it !
