I am 100% guilty of overthinking things. My first time doing all of this so I am trying to avoid dumb mistakes that could have been avoided by asking a quick question. If the collective experience and knowledge of CSC says to go through the tubes and not worry about not having anything securing the cables and wires inside the 8 foot run then I will not. Thanks again as always!
as a electrician — never put a wire tie or tape wires in a pipe or wire way were it cannot be reached! there will be a time when you will need to add something? I would strongly advise installing a pull string to add that wire for when it comes and also replacing i tech time it is used
![]() Quote:
Pro tip- use a vacuum and a rag with string attached to suck it through the tube. i have enough wadded up to pull it back and forth multiple times... or you can replace as mentioned above. |
