Old 11-14-2006, 10:11 PM
Default Bracket Project
http://www.wellcraftv20.com/gallery/...lbum127&page=1
Old 11-14-2006, 10:17 PM
Default Re: Bracket Project
Chuck's been helping me make a bracket. I got into a little mess after doing some nice glass work . . . I guess I didn't properly catalyze the first layer of glass and the tub of the braket got all fk'd up when I broke open the mold. It's gonna be lots of fairing to make it pretty, but I've got two sides somewhat faired already. I'm hoping it'll be ready by turkeyday.
Old 11-15-2006, 10:08 AM
nice job guys- keeps the pix coming- are you going to add floatation to it???? How much does/will it weigh???
Old 11-15-2006, 12:45 PM
Bigshrimpin....that looks great. Makes more tempted to try that myself....although I want a twin bracket. My questions would be...how did you determine the dimensions???
Especially the height to mount it on the full transom and the height at the rear of the bracket???
Old 11-15-2006, 04:06 PM
The dimensions were tough to figure out. Luckily strick had worked through it before.
This bracket will have a 26" setback. Supposedly you need to raise the motor one inch for every 12" of setback. So I made the bracket 23" tall which gives me a 4" gap at the bottom for the hull drain plugs. 25" + 2" (to account for the setback) => 27" = 23" (bracket height) + 4".
The width is 38" b/c that was the width of the fiberglass fabric I used.
13 degrees is what I measured for the angle of the transom.
When I calculated the positive floatation . . . I got somewhere around 400 lbs (depending on the final weight of the bracket.
Old 11-15-2006, 05:48 PM
Sorry big, I'm a little thick. The engine mount is higher
than the front top of the bracket....so is the top of where the engines mount now 27" above a line from the keel back??
Or is the bracket 23" high at the front??
I have a stainless marine aluminum twin bracket, but I really like the idea of a fiberglass bracket. This bracket is also flat across the bottom and I think a V bottom bracket that matched the transom deadrise would give more flotation and look better too.
I like your gallery of photos....
Old 12-05-2006, 11:05 AM
Totally impressed Great joy
FellowShip
My motto: Just for the Grins
Old 12-05-2006, 10:46 PM
like fellowship said.. very impressed.
Old 02-18-2007, 02:20 PM
Old 02-18-2007, 05:21 PM
Bobby - here's the layup that I used for the Bracket Tub.
2 layers of 1/2 oz mat
2 layers of 1708
8 layers of alternating 1/2 oz mat and 18 oz roving
All corners were done with 6" wide overlapping 1708 tape.
The bottom/side pieces overlap at the "keel" to there are essentially 16 layers over an inch of glass at the keel.
The tub took about 6 gallons of resin.
The swim platform part took about 2.5 gallons
I'm gonna core the platform, so I'll probably use up another 2 gallons of resin.
The widest part of the bracket was 38" (b/c I had 38" wide 1/2oz mat).
The engine stand would have helped a lot during the layup.
