  #101
Old 04-21-2014, 07:54 AM
I like the idea with the console and using the engine hatch!
Old 04-21-2014, 09:43 PM
got the coring all dry fitted , it took 7 4'x4' sheets to cut and fit everything with enough left over to do the hatches. I put corelite down where the console and leaning post will be mounted.
after everything is dry fitted, I mark everything to make it easy to reinstall after the I apply the divelette putty.
I ran out of putty and have to get more tomorrow. I got the back half of the boat all puttied into place.
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 04-21-2014, 10:35 PM
FLexpat FLexpat is offline
I am REALLY glad you decided to finish this and not sell it. Seeing the craftsmanship of your work is awesome - please keep up the documentation - I have a lot to learn.
Old 04-23-2014, 09:33 PM
guys thank you for the motivation.
lord that console is bad ass, I hope mine can look that good when its finished. does the livewell pressurized?
got all the coring done and back filled around the hatches with deck putty and layed th final layer of mat,roving
here you can see the trawl lines for the devilette putty this is how to bed the coring.
my multimaster has seen been days
still maintaining the 1/4" crown
I alright I saw my masons using these to fill the cracks between the bricks and I thought I would try them, got them from home depot for a couple bucks apiece. they really worked well for controlled putty, filleting
this is the easiest way I found to fill them
nice and smooth with no goobers or spillage
36' Yellowfin
Old 04-23-2014, 09:38 PM
here is the laminating, I had my buddy over to help, I had the glass all cut and clamped, resin in the buckets, rollers on and it took 45 minutes to lay it up. gonna pop it off tomorrow afternoon.
36' Yellowfin
Old 04-24-2014, 09:31 PM
well today was the day. got home early and decided to pop it. It was a little husky and sharp getting it up. I called in some friends that were local to help me flip it . once I got it flipped, I cut all the trimmings off with the diamond trimmer and gut the rest of the depth with the jig saw.
hatches fit really nice
here is how I got the plugs out of the hatch openings, I cut the middle out and pryed and wedged it from there. never pry on the edge as you can do damage.
here is how I cut the flange for the hatch openings, I ripped a piece of scrap up and radiused the edge for the inside
after that I took air trimmer and cut
after the last of the trimming it was time
have to trim the gas tank sending unit cover down and everything will fit.
I am waiting on a bucket of arjay technologies 1721 bedding compound. to bond the deck to the stringers.
36' Yellowfin
Old 04-24-2014, 09:52 PM
WTF ? We talking a rebirth of potter Putty
Old 04-24-2014, 10:58 PM
hey if it worked for the last 30 years why not...
36' Yellowfin
Old 04-24-2014, 11:24 PM
Takeapartable as well. Not kind, but doable.
How would you get your old fuel fill hose out if you were in my shoes?
In foam. Deck down.
Nice work.
Cheers,
Us pumpkins
Old 04-25-2014, 07:45 AM
What happened to the duratec primer that you placed down first on the lay up table??? I was expecting the top of the deck surface to be primed gray once you flipped it over. I see some of it but not much. Did it stick to the table and not stay on the resin or am I missing something???
Looks real nice btw.
