Old 03-14-2020, 04:46 PM
Got it thank you sir...I forgot about the awlgrip primer..will stick to anything..
Strick
Old 03-16-2020, 12:50 PM
rcoster38 rcoster38 is offline
Unreal. I want to throw my boat in the dumpster and take up knitting instead after looking at this project. You are a master
Old 03-22-2020, 08:03 PM
Red face
I have to strive to be, i do it for a living!
Old 03-22-2020, 08:18 PM
The devil is in the details! The little things always take the most time, well besides fairing...
Yes i was in a hurry and only measured once before cutting on these as u can see, DOH!
Untitled by dirtwheelsfl, on Flickr
Untitled by dirtwheelsfl, on FlickrUntitled by dirtwheelsfl, on Flickr
Quickie gutter material
Moved the miter saw outside for these cuts. The whole aft edge got core removed and solid glass put in for hinge hardware. The corners got filled with epoxy (red stuff) and rounded over before tabbing.
This is a piece of hollow-back rubrail with packing tape under it mushed in some epoxy to form a round profile. It will keep that edge from getting beat up. The rest of bulkhead gets core taken out of the edges, epoxy filled then glassed too... Fasteners got a full inch depth filled.
Old 03-22-2020, 09:54 PM
Nice work.
Where are you finding gloves?
Old 03-22-2020, 10:14 PM
erebus erebus is offline
Question:
When you remove the core on the edges of things (bulkheads, gunwale etc.) what tool or process do you use to do that?
I've used a cut off stubby Allen wrench chucked into a drill to remove core in a cored hull for a thru-hull or transducer or whatever, but I cant imagine how you would do it for a whole gunwale or bulkhead.
Zachary
Old 03-22-2020, 10:41 PM
lelandtampa lelandtampa is offline
AutoZone had XL gloves today. Black, blue and orange ones.
Old 03-23-2020, 08:48 AM
Originally Posted by erebus View Post
Question:
A trim router with a straight paddle cutting bit and a steady hand mostly. If i cant fit the router ill use a die grinder with some kind of burr chucked in it. A sharp stubby 1/4” drill bit works well too. Im only going 3/8”ish deep in most cases, and in high impact areas.
Old 04-04-2020, 02:39 PM
Box with a couple drawers going in here.
Gave her a bath
Only took 54 beers to flip her
Been dreading this part here!
Old 04-04-2020, 09:54 PM
Gave her a bath
You took on an ambitious project there. Did you ever learn what she hit?
