  #121
Old 08-27-2019, 07:51 PM
I'm so mad. I went to finish bolting the engine to the transom and 1 stinking hole is off by 1/4 inch.
The others are good just the 1 upper hole. Dammm I'm I pissed
I could drill it to fit but that leaves room for vibration.
What would you do??????
Old 08-27-2019, 08:09 PM
Let's see here, you have three holes that fit properly, which means no vibration in those three. If it was me I'd enlarge the fourth hole that's off by a 1/4" to fit the 1/2" bolt, fill with 5200 and tighten the heck out of it with a minimum of a double stacked 2" SS fender washer as backing.
Old 08-27-2019, 08:38 PM
I'm so pisssed at myself right now
But I guess it will pass
Old 08-27-2019, 09:07 PM
Good advice Don. But I think I might consider 4200 just in case you get pissed off at yourself again in the future and need to remove that bolt without getting a hernia
Old 08-27-2019, 09:27 PM
mr chuck
we uze duck tape an mastik ta fix big holes
sam
Old 08-27-2019, 09:32 PM
A bottle of flex seal????
Old 08-27-2019, 09:33 PM
Fill with thickened epoxy and re-drill?
Old 08-27-2019, 09:38 PM
fredbrad fredbrad is offline
easy fix, west system epoxy six10, fill the hole and drill new
Old 08-27-2019, 10:12 PM
You are right Capt., good point, however I see he is now moving on to using epoxy. That's really going to make it tough to remove the bolt without a hernia!! I'm happy he did not use epoxy to set the #10 X 1" screws on his original trim tab installation!!!
Old 08-27-2019, 10:16 PM
Naw on that I used 4200. But spoke to the glass guy said to bring it in
Oh well live and learn
