  #171
Old 04-04-2011, 09:27 AM
Default Battery Tray
Well got a little more done this weekend.
Found some batteries that were the cranking power I needed and the size that would fit the area.
Brute Force AGM...same exact battery that is made by Oddessy except it only has a 2 year warranty instead of 3 and is priced accordingly.
First I made some cleats out of 3/4 marine ply and used six-ten to epoxy in.
Next I used up some more of my left over wood and came up with a neat fitting tray. It will be held down by s/s tee nuts and painted to match the bilge.
Now the battery's. The tight fit picture is a little deceiving, both battery's fit on the tray and do not hang over ...need to get some nylon strapping to hold them down.
Old 04-14-2011, 06:01 PM
Default Moving Ahead
Just so no one thinks I'm slacking off here are some pictures of my progress in the last few weeks. No particular order to these just progress.
One of things I wanted to do before putting the floor down for good was to figure out a way to secure the engine cover to the floor without wood type screws. I did not have enough room to use T-Nuts, because a bulk head was in the way, plus when I notched the bulkhead for nylon nuts I still did not have access to it.
Here is my solution using s/s plates that were tapped for 10/24 threads.
Wood scored and 1/2 removed.
S/S Plates
Next came the floor alignment...then the epoxy and fairing compound. Now I need to tape the floor to the hull sides and do some more fairing.
After looking at the last two floor panels for a long time I decided that I needed more room around the engine.
Solution was to cut some access areas that will be hinged, so that when the engine box is opened I then open the panels.
Making the cleats for the cut out area.
Engine sitting nicely with cutouts.
Shown with cutouts opened.
The look with the engine box down
Now I feel comfortable in epoxying the last two panels down and being able to work around the engine.
Wiring for the engine should being showing up in the next few days...then I get to start it...
Old 04-14-2011, 06:31 PM
Default Re: Moving Ahead
Cool idea, Terry. She's lookin good.
Dave
Blue Heron Boat Works
Old 04-17-2011, 08:04 PM
pfbateman pfbateman is offline
Terry,
As ususal an unusual amount of forethought, innovation, and attention to detail. Can't wait to see it next week.
Fred
Old 04-17-2011, 10:08 PM
Default Start Me Up
Just a cell phone video...but I just couldn't help it I had to start it up.
Just click the picture and it should take you to photo bucket and fire it up,...
Old 04-17-2011, 11:52 PM
Default Re: Start Me Up
He He your getting there Terry....That boats gonna haul A$$. Nothing like firing up the boat and your self at the same time
Old 04-18-2011, 12:53 AM
floorboy floorboy is offline
SAHWHEAT!!!!!!!!!!!!
Old 04-18-2011, 09:15 PM
76Red18 76Red18 is offline
Did I hear a little lope??
J. M. Hendrix
Old 04-18-2011, 10:54 PM
Ryan Ryan is offline
Awesome to see you bringing that old girl back to life. and shes going to be quite a runner too! good work.
Old 04-19-2011, 01:40 AM
Wow! You're on fire.
Great idea with the hinging access on the motor sides. That's will be sweet.
Just flipped through your 400 fotos...
you been busy...
