Old 05-04-2003, 11:52 PM
JohnB JohnB is offline
Default Re: SeaMark Outboard bracket Photos
Ok,
So no one that has looked at this thread has a Hermco Bracket on????
I lost that bet.
Next, The boat is 23' by 8' beam. since it has a deep dead rise, and mine has the large top on, it can roll a little when sitting still fishing. If I put the bracket on, effectivly, I have made a 25' by 8' beam boat. Won't it be more likely to roll?
Next, with 800 or so pounds of boyency, will the nose be pointed down? and the boat not drain correctly (into the cabin) at rest?
Also, I spent quite a bit of time/money setting up a protech 4 blade prop. This rig is really hooked up. What effect will the bracket have on the proping of the boat. I got alot of lift in the stern with the 4 blade prop.
I ask again, anyone seen a setup with a 475 pound outboard on the back with the twin motor bracket?
JohnB / 23' SeaCraft
Old 05-06-2003, 10:41 PM
I usually don't reply to my own post, but...
HermCo, have you ever put a fishfinder transducer into one of those fancy brackets?
From what I can tell, that thing fits real tight against the outline of the transom.
I am looking a putting a thru hull in mine, but not real keen on putting another hole in the hull.
What do you think?
Thanks, John
Old 05-06-2003, 11:13 PM
Finster Finster is offline
John, I see your getting close to a remodel. I don't want to answer for Don, but I think that small difference in offset would create turbulence for the transducer.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 05-07-2003, 01:15 AM
Finster,
I have about decided that I will not do anything until I can look at and try out the exact setup that I intend to implement. The transom on my boat is just a little tired (250 hp 472#'s, no real rot or water penetration). The rig right now is really well hooked up. I just would like a little more room, and a little less water slooshing around in the splash well. I am working on a design that I want to implement back there, and when I get done with the drawings, I will post it. I'm thinking of putting in a removable insert fish box/live well back above the splashwell, and a fold up convertable bench/jump seat in front. I'm also looking at some options with the live well in the floor. Drainage and balance are 2 important factors. Also toying with the idea of relocating 1 or both of the batteries.
Old 05-07-2003, 09:27 AM
hermco hermco is offline
I have not installed a transducer in one of the "fancy" brackets and I doubt it would work. The bracket sits higher than the bottom of the boat creating a "stepped" hull effect therefore the ducer would not allways have a clean flow of water across it. [img]images/icons/cool.gif[/img]
Old 05-08-2003, 05:47 PM
JohnB,
I've got some pics of an above floor livewell in my last Sceptre and I also moved the batteries inside the cabin with pics If you would like them. My boat was a 77 and I converted the splash well floor livewell into a fresh water tank.
DaveH
Old 05-08-2003, 06:37 PM
Thanks, for the heads up HermCo. I didn't realize that it was a step bracket. I am putting a roof on the homestead next week, so the bracket will have to wait a month or so. If you have a boat/bracket combo down there that has a bracket on it, I might make the trip down to see how it look/works, and the layout in general.
That70sboat, I would be grateful for any pictures. I have a couple of ideas, and when I get them down on paper, I will post them and see what you all think.
Old 05-08-2003, 08:24 PM
That70sboat,
I have an '82 Sceptre and would also be grateful to see your above-deck livewell. Right now I'm trying to answer the question "to plumb or not to plumb?". Can't decide if I should plumb the in-deck well or just do something above deck.
Welcome to the board . [img]images/icons/smile.gif[/img]
Old 05-11-2003, 11:10 AM
abl1111 abl1111 is offline
That70'sBoat,
I would loike to see your pix of the above deck live-well. I have been thinking about the same issue.
Thx
Alan
Old 05-16-2003, 01:16 AM
Anyone got pictures regarding the topic above?
If you have trouble posting them, e:mail them to me and I will post them for you.
Thanks.
