Old 11-18-2003, 12:44 PM
MarkR MarkR is offline
Default Re: starboard to flush mount electronics
I really like the engraving stock option. I am planning to re-instrument my Sceptre this winter and have found a few manufactureres of the engraving stock. I have not yet found one that has a similar woodgrain to what they used at the factory that can tollerate the UV and moisture. The plan is to replace the glove box as well and engrave the "Sceptre" text back in as well as the switch and fuse panel text. Anyone gone down this road?
Old 11-18-2003, 02:45 PM
Hey Gang
There is some new material on the market which is "Expanded Foam PVC" I used this stuff vs starboard for the gauges & back board. It can be cut, sanded, routed, shaped, painted, sealed and it's waterproof and stiff. It is a grey color in it's raw state and is available in different thickness 1/8" thru 1".Check with your local sign manufactures.
If not, there is an outfit here in Stuart,Fl called "Fantastic Plastics" (772)223-8005 who carries it. I think Mark Lewis is having some replacement parts manfactured for his boat at this place.
Just some alternative options for you [img]images/icons/cool.gif[/img]
Old 11-19-2003, 01:57 AM
gw204 gw204 is offline
Mark,
The stuff I got comes in two grades, indoor and outdoor. I asked if the outdoor would stand up to the harsh marine environemnt and the guy told me yes, so that's what I got. It was almost twice as expensive as the indoor stuff.
After almost year, it still looks new. But the console stays covered when I'm not using the boat. Only time will tell but so far, it's holding up well.
Brian
1981 Mako 17
