Old 12-17-2003, 03:03 PM
Default Re: Fuel Tank Support
Abl,
You did it perfect. With epoxy and Awlgrip your tank is virtually impervious to corrosion on the outside. It is the absolute best way to do it. If you don't have tabs on the tank sides you can foam it in with cross members over the top to keep it from lifting in the foaming process. Make sure to lay down strips of 1/4 inch starboard or hard rubber strips under the tank to allow drainage.
Old 12-18-2003, 12:17 AM
cc cc is offline
I have built a new aluminum tank from 5052-H32 marine grade aluminum for my boat ( we are metal fabricators), and was thinking about taking it to a shop that does the spray on bedliners. It is supposed to be impervious to anything, and not harmful to aluminum. Anyone have any experience with this, have you tried it? Previously I have always painted with zinc chromate several coats to protect the aluminum like is done on aircraft parts.
Old 12-18-2003, 01:27 AM
Once again thanks for all the comments.. I really appreciate it because it helps to stimulate my gray matter to come up with new ideas.
John R - thanks for the back up support. I still have all my pics but I'm just a little dis-organized as to were they all are. Glad to see that my pic's made it to your Projects/ Inspiration folder [img]images/icons/wink.gif[/img]
Capt Chuck- We must have a different design to our boats. My tank sits right up against the forward hold (the stepdown compartment in the consel) so there is no room to put a fresh water tank in front of the gas tank unless I do away with the stepdown compartment and make the floor inside the consel level with the main deck.
Kglynn- 1975 model
Otto- right now all my buddies are killing ducks and catching stripers and sturgeon and I still would rather be working on this damm boat.... go figure.... my mother must have dropped me on my head when I was a baby.
Scott- yea it's good that we are checking everything... there used to be a head in the stepdown compartment in the consel and I could see were the previous owner had done a sloppy job of removing the plumbing and glassing over the area so I decided to remove the stepdown compartment and take a look at the patch job they made to the hull and sure enough it did not look to good so ground out the area and epoxied over it just to be safe. Here are a couple pics of that.
abl1111- I'm going to do it just like Fellow ship posted from the Pascoe site (had it saved as well). That Pascoe knows what he is talking about. He says dont use any rubber strips on the bottom of the tank (to keep it from sliding) so when I pulled my tank out sure enough it had rubber strips stuck to the bottom of the tank and when I pulled them off there was severe pitting into the aluminum. That was the only place were there was corrosion on the whole tank... right were each rubber strip was. Foaming in the tank will keep it secure however often times water will find it's way into the foam. So make sure there is a way for the water to get out. Good that you coated the tank and I may do the same.
Chris- I'm self employed so I get to take a day off when ever things are slow. I decided to use high quality 3/4 inch plywood for the tank to sit on. I'm glassing both sides with a layer of 1708 and will make a bed of cabosil along the edges were the base meets the hull and also will cabosil it to the keel stringer. Then I will glass it up the sides of the stringers. I decided to go with the wood for the extra weight plus I did not feel like driving the 2 hours for composit [img]images/icons/rolleyes.gif[/img] Upon thinking it over I think it is a good idea to keep things as light as I can in the rear of the boat (by using composit) and add a little extra weight in the middle (with the wood)
Strick
Old 12-18-2003, 10:28 AM
Ha Strick
I also went with ¾” marine plywood with lamination on both sides. I almost had a problem that I thought I would worn you about. By increasing the thickness of ¼” with glass lamination and by placing the gas and air filler 90 degree pipe approx at the same location as the old tank I had a very tight fit of the deck on top of the tank. The guy that made the tank for me made those 90 degree gas fill a little too high and my top deck would have rubbed against it. I was going to put a air vent in anyway so I decided to put my air vent right on top of the 90 degree filler hose locations just to be safe.
Old 12-18-2003, 11:49 AM
Thanks Fellow-Ship... it's a tight fit in mine as well. I finished glassing in the new tank support last night so I'll take a measurment today with the top deck on (also has 3/4 inch marine ply) before the welder starts making the tank so I can give him. Have to figure hoses, clamps etc... for a maximum height [img]images/icons/smile.gif[/img]
Strick
Old 12-18-2003, 11:55 AM
Rich Rich is offline
Looks familiar....
http://seacraft.snetsol.com/inside.htm
Cape Marine Supply
Old 12-18-2003, 03:41 PM
Capn Chuck,
I've been at it for almost three years now. Why you ask it's taking so long? Primarily money issues, but also not much free time. I have another 4-5K that I need to put in to be ready for launch.
I am pretty much done with all the rough work; transom replacement, rebuild of front fish well, rebuild of fuel tank area, patching and fixing holes of all shapes and sizes. I have already purchased the paint I will be using to paint the outside of the boat as well as the cap and deck of the boat. I have rough sanded almost all surfaces that need paint. I have also rebuilt my console more to my liking.
Already have a new Fuel tank ready to go. I bought a brand new in box 2001 225 Evinrude last fall.
Things I still need:
Hydraulic steering
Rewire the boat
Electronics
Leaning post
All the rigging for the engine including prop
Misc. items....
I really haven't updated my progress pictures for some time. You can see some of the originals at http://seacraft.snetsol.com
Cape Marine Supply
Old 12-18-2003, 05:20 PM
Rich
Boy you really have had your hands full [img]images/icons/shocked.gif[/img] By the pics you have done a great job. What year is that wiring detail from?.
I guess I have been lucky as I am the 2nd owner of my boat and have owed her since 1985, so I have been able to stay with it and not let severe damage set in. [img]images/icons/wink.gif[/img]
I still will be inclosing the transom and installing a bracket. I'm starting to get some bleeding at the engine bolts and motor well cap. After 25 yrs I know it's time. [img]images/icons/frown.gif[/img]
[ December 18, 2003, 04:20 PM: Message edited by: capt chuck steele ]
Old 12-18-2003, 06:02 PM
Scott Scott is offline
Hey Strick ...Are you replacing those "level platforms" (used for the batteries) towards the stern of the bilge where the big stringers go outboard 90 degrees??? They look similar to mine ....as in the color is dark ...making me think they are rotten ... I know Fellowship found that when he took his apart.
Ironically I have that space under the console for the head ...BUT .... its nothing more than an empty void with the deck inside the console...I cant figure out why they would have wasted that space ....But I wont !!
Rich …those wiring diagrams are pretty neat !!
Old 12-18-2003, 11:23 PM
John R John R is offline
Hey Strick - when I pull my console off to see how forward the tank goes, if I have enough clearance, I want to put that console well in. I might want your old one [img]images/icons/grin.gif[/img] [img]images/icons/shocked.gif[/img]
Surf and Boat fishing for
Striped Bass
