Old 12-30-2003, 10:08 AM
Sceptre Sceptre is offline
Default Re: Paint ques.
Scott is right on the mark... the Lemon Mist offered by Sterling is the closest to the original Potter era "yellow" gelcoat color. I know because I spent 3 months searching for a color that would be as close to the original as possible. After many test samples and mucho $$$, this was BY FAR the closest color match I found. I painted my 20 Sceptre in this color using Awlgrip paint - sprayed on. I then added the standard 1.5" inch wide single black boot stripe (3/4" above the chine edge) which was typically installed on yellow 20 footers back then. FYI: no one makes an 1.5" wide boot stripe vinyl tape, so I had my local sign shop fabricate and install it. Turned out perfect.
Old 12-30-2003, 06:38 PM
Hey Mark
Mine started out that way until I was called "Bananna Boat" too many times [img]images/icons/grin.gif[/img]
I corrected the problem real quick!--->
http://www.theboatzone.com/gallery/CSteele/res8246
Used Signature Finish, no primer, no spray, easy to repair [img]images/icons/cool.gif[/img]
