Old 04-07-2002, 09:32 PM
Default Re: Scuppers
Scott, He put them right in line with the originals that went thru the hull .He cut out the bottom of a thru hull plastic fitting about 2 inches in diameter, That way it drains as much as possible when water runs towards the corners were the original drains were before. When he closed in the back he also did a channel so water can rum either to the port or starboard side.anyways he used a flex hose from that thru hole to the scuppers.Mike up in Stuart has done several this way,his shop is called Wildfire Marine.He closes up transoms,mounts brackets etc.I did not want to trailer my boat up ther but when I spoke with him and saw some pictures I knew thats what I wanted. All the problems I had before are solved. Water not coming in , More room, a live well that actually works right and you dont have to bend down to get your bait,pumps easy to get to, Fish box,easy to get in and out of the boat not like before in was a hassle,I can back down now when its rough, much better ride,I can get into shallower water to get bait,Plains quicker, over all I dont need to spend a fortune on a new boat,These changes made the boat alot more enjoyable. Ill try to email you some pictures. Would you be able to post them? Capt D.
Old 04-07-2002, 09:41 PM
Scott about the bracket,I have a friend with a 72 boat identical to mine he used a smaller bracket that did'nt have the buoyancy chamber and his boat squats alot,for that matter draws over 3 inches more that mine.If someone decides to put on a bracket go with a wide body, I'm telling you it will make all the difference in the world,you'll love it. How long has this Seacraft board been open? Thanks Capt D.
Old 04-07-2002, 11:55 PM
Scott Scott is offline
Capt D
Thanks again for your information ...
This Forum started up around the end of February 2002 by Jason Goldfarb AKA Trayder...as far as the website.. we'll ask Jason those details.... We all owe him a great deal for what he has done by facilitating this site.... The information that is exchanged and shared around this site is tremendous....especially for those of us in the beginning or middle of a restoration. Without this site I couldnt converse so easily with guys like yourself to get ideas for my restore.
Jason I said it once .... and I'll say it many more times THANKS FOR THE GREAT WEBSITE [img]images/icons/wink.gif[/img]
As far as the pictures go...your more than welcome to send then to me....however I will just end up sending them to Jason (admin@classicseacraft) so he can put up your own page with your story about the boat and pictures...Sorry Jason...I'm making more work for you [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img]
Oh yeah....All of the brackets that I've looked at, either on the boat or inquired about, are the floatation type....as you suggest I dont know why you would put a non-floatation bracket on your boat...I'm sure thats how the originals started out...but why would you put one on now with the other available ....I guess there's a reason for everything...
[ April 07, 2002, 11:34 PM: Message edited by: Scott ]
Old 04-10-2002, 10:18 PM
Briguy Briguy is offline
Reel Smoker,
Where do you buy the cone scuppers. Do you have any pix of them? I am thinking of doing the same mod that you did.
Capt. Brian
Old 04-10-2002, 10:36 PM
I'm looking into those also they are call rabud sea scuppers I think reel smoker said to get the large ones.....click on the link and then click pg. 586
Boatfix.com
http://www.boatfix.com/bymfg.ASP?make=RABUD
Old 04-11-2002, 12:40 AM
Briguy,the ones that were installed on my boat were the large ones I believe they make 2 sizes. They are made by Rabud.I was concerned when I put the boat in the water that the cones would be under but the way that the bracket was installed was right on the money,the bottom of the scupper is even with the water line,just a small amount of weight in the corners backs the ball up to towards the transom and it seals completely.I wanted to go with the Sea stop scuppers but Mike at Wildfire Marine suggested these because they dont let a drop in.Im working on getting the pics together .Ill send thenm to Jason as soon as I have them.Mike at Wildfire has done this to several 23 seacrafts,he knows what hes doing,he bought the scuppers and put them on so I really dont now were to buy them.Capt D.
Old 04-11-2002, 10:51 AM
Try www.Rabud.com
Capt. Brian
