Old 01-28-2003, 12:39 PM
Gary S Gary S is offline
Default Re: FUEL TANK REMOVAL
I installed some new tanks in one of my customers boat after he had started the job. He told me that he blew the foam out using a 2000# preasure cleaner. I didn`t see it done but it sounded lite something I might try in the future.
Old 01-28-2003, 06:47 PM
REPETE REPETE is offline
I have a 100 gal. tank and want to increase to a 120 to 130 gal. tank. Who would be a good vendor?
Old 01-29-2003, 09:59 PM
ltdan ltdan is offline
HEY REPETE,,, HOME DEPOT OF COARSE,,,, THEY'VE GOT EVERY KIND OF CHAINSAW KNOWN TO MAN [img]images/icons/rolleyes.gif[/img] LT DAN
Old 01-29-2003, 10:34 PM
Matt1121 Matt1121 is offline
Lt. Dan-
Your method of hooking a tailpipe to a gas tank to add carbon monoxide so as to remove the oxygen is very interesting. I've never heard of that before....all I heard of was draining the tank of all the gas and filling it with water.
Any suggestions for when the foam surrounding the tank is soaked with fuel or fuel vapors? I'm being serious and not trying to be a wisea$$.
Ed
Old 01-30-2003, 09:35 PM
LIKE I SAID BEFORE ED,VERY CAREFULLY! DUE DILIGENCE IS THE RULE OF THUMB IF YOU'VE GOT A LEAKER WITH SATURATED FOAM. SOMETIME'S IT PAY'S TO USE THE PRO'S AND PART WITH THE BUCK'S. ED,I DON'T THINK YOUR TRYING TO BE A SMARTA$$, THE VERY FACT THAT WE TAKE THE THE TIME TO EXPLORE ALL THE ANGLE'S WILL BE A BENIFIT TO SOMEONE,,MAYBE PREVENT SOMEONE FROM MAKING A BIG MISTAKE [img]images/icons/frown.gif[/img] . THIS IS A SITE OF DO IT YOURSELFER'S THAT SEEM TO BE BOOTSTRAPPER'S BY NATURE, AND I THINK WE ALL SHOULD SHARE OUR EXPERIENCES. THE COMMENTARY THAT COME'S AFTER AN ORIGINAL POST, IS WHAT WE ALL RELY ON TO FINE TUNE OUR PROCEDURE'S, OR THOUGHT PROCESS PRIOR TO ATEMPTING A FIX OR REPAIR,,,,PURCHASE OR SALE,,,ETC. IF WE STOP DOING THAT,,,,THIS SITE LOSES IT'S MOST VALUABLE COMMODITY,,, INFORMATION. MOST SERIOUSLY LT DAN
Old 01-31-2003, 06:32 AM
CRO CRO is offline
I just started to take the tank out of my 73 23 Tsunami and it dose not apear to be fomed in. I just drained the fule out last night and this afternoon I am going to try and remove the tank. What do you do with the fill hose to get it out of the way? Also how do you put in a new fill hose? Thanks for any info. Chris
Old 01-31-2003, 04:18 PM
AFTER YOU DISCONNECT THE HOSE FROM YOUR TANK YOU CAN UNSCREW THE GAS FILL BRACKET THAT IS MOUNTED ON THE CAP OF YOUR BOAT PULL THE HOSE UP ABOUT A FOOT OR TWO DO THE SAME THING WITH THE AIR EXCAPE HOSE THEN THERE SHOULDN’T BE ANY TROUBLE REMOVING THE TANK EXCEPT FOR THE WIRES FROM THE GAS TANK TO YOUR GAS INDICATOR AND A GREEN GROUND THAT MIGHT GO FROM YOUR TANK AND YOUR GAS FILLER TO A BOAT GROUND. AS FOR INSTALLING A NEW HOSE FIRST OFF MAKE SURE YOU BUY THE GAS TYPE HOSE NOT THE WATER OR EXHAUST TYPE HOSES IF YOU REMOVE THE HOSE CLAMPS FROM THE GAS FILLER YOU COULD ATTACH THE NEW HOSE TO THE OLD ONE BY USING SOME LARGE PVC PIPE WITH HOSE CLAMS HOLDING THE OLD ONE TO THE NEW TOGETHER. THEN JUST PUSH IT THROUGH. MAKE SURE YOU USE 2 GOOD HOSE CLAMS ON BOTH THE TANK AND ALSO THE GAS FILL JUST INCASE ONE BREAKS. THERE IS ONE LAST THIN TO DO WHEN YOU RUN THE NEW AIR EXCAPE LINE MAKE SURE YOU HAVE A LOOP IN THE LINE LIKE A U JUST BEFORE YOUR OUT BOARD VENT BY DOING THAT IF ANY WATER DOES GET INTO THE LINE FROM THE VENT TAKING IN WATER IT WILL NOT HAVE ACCESS TO YOUR GAS TANK IT WILL GET CAUGHT IN THE LOOP. WHEN YOU FILL YOU TANK WITH GAS IT WILL GET BLOWN OUT THE VENT.
FELLOW-SHIP [img]images/icons/wink.gif[/img]
Old 01-31-2003, 06:22 PM
FYI,
Shop around for that fuel hose. I found prices between $9 to $6 a foot.
Same hose, different thief ...
- Nick
Old 02-04-2003, 04:21 PM
Trayder Trayder is offline
Velvet Jones
Check out these guys:
Surplus Unlimited
Awsome prices on 2" fuel fill hose $5 a foot and amazing prices on marine wire. All Marine quality, they have been very realiable for my needs.
