Guys,
Taco makes something similar and you can buy it 25ft to 100 foot rolls. Plus you can get it in white or black, and different widths. JW Also stainless clip, no rusting |
Honey Hole,
I advise you to drill out and fill all of those holes with thickened West or equal. I'm sure you have a few others while you're at it. Touch up with gelcoat and it's like they were never there. I suggest the Taco u-channal as it has stainless steel clips. The stuff at the auto store is steel. How long do you think that would last? Do it right the first time.
Otto And yes, I still believe in the four boat theory... |
My buddy used the u-shape trim,seems like every time He got next to it (bumped),it would slide down,even put sealant on it .Maybe the constant 100* heat Here?I have some of the trim That I can send a peice to whoever want some.It covered all the holes & I heated it with a Heat gun ,went right around the corners even the front inside tight.
I put a screw every 4"s could probably go up to 6".I made a JIG, placed next to a screw then drilled a hole.Its 1 1/8 top to bottom,Has a lip on the bottom to follow the edge.Also has a bevel?rounded at the top to finish it off. Comes in 20' lengths,1 piece.It took 2 peices 1 on each side to do My 20'r started in the bow middle.I got 3 for around the inst.panel & under storage console,also variuos other trim pieces. e-mail Me for the a sample piece,I'll drop it in the mail. Scream'n Reels' [img]images/icons/cool.gif[/img] Capt. Brad www.frenzie.com Frenzie Lures,Inc.
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
