Old 02-02-2004, 03:24 PM
Mi Time II Mi Time II is offline
Default Re: Choosing a new trailer
ztagator, check the pic out on this forum. web page I have an 18' with a tadem Rolls, and wouldnt trade it for the world.
Old 02-02-2004, 06:35 PM
JohnS JohnS is offline
Personally, I like the Loadmaster. Nice stuff and never been a problem. Also, personally, two axles are better than one any day in my book. I have had the pleasure of a blow out with a single axle and it was less than a pleasure. Oh, and that occured with less than 100 miles on the new tires that were on the trailer that was less than three months old. I have also had the pleasure of having a spring go on a single axle trailer, again, less than pleasurable when you are running down the expressway! So, those are my reasons for my very bias opinion on one axle versus two.
I have a Loadmaster under the new ride and I love it. Loads easily, unloads easilt, cleans easily, rides as if it was on air. Wouldn't trade it for the world.
Now, I have seen Capt Brad's new baby and it was pretty nice too, though I admit I did not look at it really close. Next time we get together, I will make a point of a closer inspection.
John
Old 02-02-2004, 08:51 PM
TarponTom TarponTom is offline
I paid extra for aluminum wheels once that looked great for a few months. When they started to errode it was fast! Maybe dissimilar metals in salt water, I dont know but it's galvanized now for me.
Tarpon Tom
Old 02-03-2004, 12:25 PM
Briguy Briguy is offline
Does anyone have an idea on how to make trailer parts last longer. My continental galvenized dual axel trailer is already showing some minor signs of rust forming. I sprayed the lug nuts with corrosion x max wax. Am I better spraying highly succeptable parts with cold galvenize, like the hubs and springs? Springs seem to really rust after only a few years. Had I not got this trailer for under $1200 bucks only 4 months old, I probably would have gone with an aluminum trailer,stainless package with turbolube hubs. I guess my question is am I better coating the trailer springs with cr X or cold Galvin spray? Oh yeah, Pettit makes this stuff called metal prep I used on the inside gas tank of my motorcycle. Maybe that would work.
Capt. Brian
Old 02-03-2004, 12:50 PM
TUGBOAT TUGBOAT is offline
Briguy
When My ol' trailer started that I wire brushed what I could sprayed with Ospho.Then used a metal etching primer then a Allum. (grey)colored paint.Did'nt want to get rid of it after that.
Scream'n Reels' [img]/images/graemlins/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 02-03-2004, 08:51 PM
Briguy,
I replaced my springs with torsion axles but when I originally bought my Slide-On they coated them with a thinned-down roofing cement. I redid them yearly and it seemed to help. Thin it with gas and brush it on, messy as hell though.
Tarpon Tom
Old 02-04-2004, 09:36 AM
Briguy
There is not much you can do about the springs rusting especially when in the saltwater environment [img]/images/graemlins/mad.gif[/img] With proper care you should get at least 10 years out of them. They can be bought for approx. $25-$30 each when needed.
In the interim, I go to Kmart and get the "Rust-proofing / Rubberized Undercoating Spray" from the auto dept. Approx $4.00 a can. Two cans will do it!. Make sure the springs are dry and spray the $hit out of them. You can use a throw away brush and dab some in the tight areas. Use a piece of cardboard as a backdrop, a drop cloth and throw away gloves as the stuff splatters everywhere [img]/images/graemlins/blush.gif[/img]. I double coat the axels also. Seems to hold up about 2 years. You also can get this stuff called "Trailer Coate" which is quite expensive but works extremely well. Boater's World and West Marine carries it [img]/images/graemlins/laugh.gif[/img]
I would highly recommend that you bite the bullet and replace the "U Bolts" and all others with Stainless before they rust up and give you real trouble. [img]/images/graemlins/wink.gif[/img]
Old 02-06-2004, 03:00 PM
BriGuy,
A good coat of 10w-30 on the leaf springs and grease on the threads of the u-bolts once a season doesn't hurt if you want to prevent rust.
