Old 02-04-2004, 05:57 PM
JohnS JohnS is offline
Default Re: Pathfinder 2300 V
TG,
If you would like to look at a boat that you can use for MANY purposes, take a look at a Concept. I am not saying they are the best for offshore but, they are a great boat and they do NOT have a balsa cored hull. That is what I am running now and I personally love the boat. They can be found at www.conceptboats.com
Hope Trayder doesn't boot me off for this.
John
Old 02-04-2004, 09:43 PM
Read these.
http://www.yachtsurvey.com/searay_ba...re_bottoms.htm
http://www.yachtsurvey.com/cored_hull_bottoms.htm
John
Old 02-04-2004, 10:09 PM
Trayder Trayder is offline
Velvet Jones
Guys, I have to disagree with those doubting the cored hulls on the Pathfinder. I will not doubt your concerns with cored hulls in gereral but I am not too sure every one here realizes how different Pathfinders cored hull is from say a Blackwatch or other typical cored hull.
Pathfinder literally vacum bags each hull sucking the resin into the grain of the balsa core. Other cored boats simply spray gel coat in the mold, lay roven, lay core mat, and then lay roven over the core, allow to cure and pop out of mold this is what creates problems as there is no way for ploy to wick into the core if you just lay it over. Pathfinder goes through an intense process to assure the resin gets into the core which as Skip says makes it bullet proof.
here is a pic of a boat in the mold:
I hopped aboard one and was really impresssed, its a tad small for 23' and it does not share a seacraft hull design as TG thought but the wide gunwales, large console, agresive deep V, pitch bait wells, large livewell and composite construction has me sold. So much so that I advised one of my very good fishg buddies to buy one. ( I suggested a classic SeaCraft first of course but he wanted a new boat and is not very "hands on" althogh he liked the beer to work ratio) [img]/images/graemlins/grin.gif[/img]
He got a demonstaror model straight from Pathfinder and is happier than a pig in S&%$. Pathfinder has treated him like he bought a new boat and he has had it out almost every day since he bought it, he is down in the panhandle of FL. I am looking forward to going for a ride when he tows it up to CT for the summer.
Old 02-05-2004, 12:06 AM
TG_190 TG_190 is offline
Thanks for the suggestion for Concept boats, too many things working against them for my given situation. They seem well made, but not right for me.
Well, I've read all that Pascoe has to say about cored hulls, and such. What he says in the several articles I read makes sense to me.
Traydor, or should I say Traitor, (just kidding) I have heard that vacum bagging is a good technique, but you still do wind up having balsa below the water line (which pascoe drives home as a no-no). What are the best materials for stringers, as a lot of boat companies are advertising the high-tech "foam filled stringers". Is balsa used in the hull for chines/strakes as well?
The dealer I spoke with (Waretown,NJ) told me that the design was based on the SC23. I like the lines of the boat, and the story on the pathfinder site is compelling, but somewhat "deceiving" in that they neglect to mention the coring, yet go into gory details regarding the vacum bagging thing.
I guess it says a lot that you reccomend this boat to a bud.
Unfortunately, Pathfinder is not gonna be at the AC show.
What other boats would you consider??????
I am gonna be at the AC show, and want to give a good look at what deserves my time:
Triton,
Hydra-sports,
Sailfish,
Cape Horn,
Sea Craft,
SeaVee(?),
Yellowfin (?),
Contender (?),
Grady,
BW,
Dusky,
Robalo,
Regulator (?$$$),
etc.
Regards,
TG_190
Old 02-05-2004, 12:46 AM
Velvet Jones
TG-
I would not recommend taking what Pascoe says as 100% truth. Having read most of his articles he brings up many good points but his opinion often fogs the truth on some matters, do not take what anyone says as godsent, Pascoe, Powerboat reports or any one for that matter.
As for balsa under the waterline I if done right, as thepathfinder is, and well maintained, which every boat should be if you want it to treat you right, I would not hesitate. In regards to the chines/strakes I think they fill them with somesort of a resin before the balsa is laid down, I know that is how Contender does it except Contender only cores the hull sides and has a solid bottom.
you have to understand with production boats, there is no best boat or best built boat. All boats are compromises in one way or the other and the same goes for the way they are built.
As for your dealer saying the pathfinder is shares the SeaCraft design he is mistaken, it has reversed chines on the bottom not the variable deadrise hull as SeaCraft is knowm for, I will agree they are similar looking but they are vastly different in design and construction.
You have a good list going, although you are all over the board (which is good), I do not think you could add any, except the Conch27, and you should look at them all and figure out which config/build fits your needs then take the final 2-3 for a seatrail and make your decision.
Old 02-05-2004, 10:05 AM
Ha TG
I’m responding to your list of boats you put up it seems to me you are looking at 23 footers or their about size for a few reasons like trailer ability, one engine boat of very good quality. If I am correct, then if I were you I would narrow your list to just a few. That make excellent boats in that size. My list would be the 23 SeaCraft, 23 Contender, 26 SeaVee which is a 25 with a built in bracket and does fine with one engine, and the 23 Yellowfin all these boats do not have cored hulls and if you ever decide to sell her many people would be interested in paying a fair price to get her from you.
FellowShip
Old 02-05-2004, 01:53 PM
Keep the Hydra Sports on the list as well. Their Vector Series 24 is a great boat with Very good range (350 MI), and a very smooth dry ride. Although the hullsides and decks may be cored I don't believe the hull is. At least not when I sold them a couple of years ago. But I could be wrong now.
http://www.hydrasports.com/Boats/Boa...=1&bid=71&sn=7
Old 02-05-2004, 08:12 AM
TG,
I agree with Trayder here, and this is why. After I finished reading all of those articles, it seems that person is biased in some ways and if you really read deep inot it, it really seems there is, and pardon the expression, a hard-on for SeaRay in most of the articles. After investigating more last night, I still think the Pathfinder is a great boat. I have had the time to look at at them and they are a well made boat. Trayder's points on vacuum bagging are well made and again, I agree. Trayder's point on proper care with any boat is well made and is sooooo true. That is why we all look up to him so highly around here and that is why he is The Man!!!!
Suggestion, call the gentleman that responded to my email. He seems knowledgeable on the boats and if you need any other info, I am sure he will get it to you.
John
Old 02-05-2004, 03:02 PM
TG,
I am going to the Miami Boat show during the next week. Skip, from Maverick Boats, has been kind enough to invite me to meet with him at the boat show. I will speak with him personally about all this stuff and get the skinny on the boat. Skip seems to be a genuine type guy and has given me his cell number to contact him at the boat show so we can meet up. They will have one of the boats inside at the show as well as in the water, according to Skip. Maybe all the CSC guys that are going should all meet up together and we can all go over to skip and tie him up and interigate him!!! Anyone have the bright lights????
John
Old 02-05-2004, 08:50 PM
TUGBOAT TUGBOAT is offline
I have some really Bright "GLOW" in the Dark Bullet Lures ! in "3" Sizes,Whatcha' got in Mind ? [img]/images/graemlins/blush.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
