Old 03-07-2005, 11:16 AM
Default Re: Spraying Gelcoat and Awlgrip?
Awlgrip
Recommends you “just use their soap, and cleaning liquids”, as for wax I can’t see why you would need to wax a awlgrip paint job that stuff always has the wet look to it and if it doesn’t it probably is over 10 years old and needs painting again.
FellowShip [img]/images/graemlins/cool.gif[/img]
Old 03-07-2005, 06:45 PM
abl1111 abl1111 is offline
I have used "Gary's Cleaner Wax ( West Marine ) on awlgrip and it cleans it great - when nothing else does, and leaves a little wax on too. It is GREAT stuff!
Old 03-08-2005, 11:27 AM
NoankBill - when spraying gelcoat with a presssure pot sprayer . . . how much sanding is involved to knock off the orange peel?
Old 03-08-2005, 03:40 PM
optiguy optiguy is offline
That subject will take me too long to answer here. PM me and I will give you my phone number and I will tell you what I have found to be the best way to use a pressure pot.
Bill
Old 03-08-2005, 06:00 PM
Thanks Bill
Old 03-08-2005, 08:31 PM
edloh edloh is offline
how durable is awlgrip? thinking of repainting the interior of the boat but concern with how it will wear on awlgrip. ie spots that would show through. any experience on this?
Old 03-09-2005, 07:03 AM
alarie alarie is offline
For small repairs like you are talking about, we use a siphon gun (SATA gun is what we have) with a large tip to spray gelcoat without problem. Pressure pots are great and do work better, but they are not practical for the hobby guy to own and use. With either gun you will have to sand, so it is really no big deal how the spray job comes out. We get some pretty nice finishes with this method, and generally start sanding with 320.
Mix:
Gelcoat, 20% Duratec Clear High Gloss Additive (not the clear high gloss finish, which is thicker), and then thin with MEK 5-10% to get a nice spray consistency.
Method:
Spray 1 light coat without wax and let kick until firm. You can then pinhole your surfaces-we use a foam brush stripped of the foam cover, leaving the flexible plastic undercore which you use as a squeegee. Mix a small batch of kicked, unthinned gel and swipe it into the pinholes. You can be pretty neat with this tool, so don't make a mess.
Once pinholed, go back and spray 2-3 more thin coats over the area, adding wax to the last 1-2 coats so that the surface will dry. Wait 10 minutes or so between coats (kick separate batches of gel from one "master" batch that you mix at the beginning.) We get nice results with this method and often do not sand the surface in non-critical areas.
I am planning on gel coating the inside of my project 20 with this method, and will likely not sand any of it.
You can also use the same method for great non-skid application. Spray your surface so that the color is down and you have good coverage, then mix gel as above, thin it a touch more, and add your non-skid (we use Awlgrip particles) and then spray one SUPER LIGHT pass over the area. Too much spray and you will just bury the particles under the gel, so go light and you will like the results.
Good luck and email if ??
Peter
Peter Alarie
"that won't take too long, will it?"
alarie404@mac.com
Old 03-09-2005, 10:18 AM
warthog5 warthog5 is offline
Wouldn't a single edge razor blade work easier for filling pinholes?
I've been doing it that way for a long time.
Old 03-09-2005, 12:15 PM
The single edge razor works well, but the gel/paint needs to be fully cured or you will scratch the surface with the edge of the razor. With the foam brush core, it is very flexible and allows you to work quickly on a slightly green surface.
Both work well, but I generally use the foam brush core on gelcoat jobs and the razor on epoxy/Awlgrip jobs.
Good luck!
Peter
Peter Alarie
alarie404@mac.com
