Old 09-24-2004, 11:08 PM
Scott Scott is offline
Default Re: Electrical or Fuel Delivery?
I'll tell you about the fireball over a few beers....
Ahhh haha haha ... FIRE FIRE !!!!
Glad I wasn’t around for that one!!
Old 09-25-2004, 02:32 PM
Seems like I may have found the culprit - loose and/or dirty battery connections. Although to the touch they didn't seem real loose, I guess they were loose enough to cause an issue. However, as I slowed down entering the river back to my mooring, the engine exhibited the problem again around 3000 rpm. I throttled back up, then down again and it did it again. Right after it happened, I checked the fuel bulb and it was soft. Perhaps I have poor fuel flow too?
Old 09-25-2004, 08:03 PM
Finster Finster is offline
Scott, you'll need to check your fuel pickup on the tank. A lot of times they put these fine mesh screens on them, and if you have crap in the they can get clogged quit easily. I had a simular problem with the aquasport. I just simply took the screen off and let the "what ever" go into the canister filter. Worked like a charm.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 09-26-2004, 08:40 AM
Chris,
That's what my mechanic told me to do too, but I didn't get around to removing it yesterday. Great minds think alike. [img]/images/graemlins/wink.gif[/img]
Old 09-26-2004, 09:27 AM
John R John R is offline
Will the fuel filters TRULY clean out the fuel? If I frequently change the filter and cycle newer gas through? Should be OK? My 3 year old kid will be in collegde by the time the mower sucks through this tank....
Surf and Boat fishing for
Striped Bass
Old 10-22-2004, 09:03 PM
daddyo daddyo is offline
Check youur grounding system and it's associated connections. Sounds electrical..
Conch Style
