Old 11-15-2004, 05:21 PM
rockdoc rockdoc is offline
Default Re: Trailer Question - spec and set up needed
Otto-
Thanks! I'm going to build some bunks and try them out.
Steve
Old 11-15-2004, 06:44 PM
abl1111 abl1111 is offline
Otto, Thx. Your bunks - are they 4x6 or are they (2) 2x8 screwed together?
Thx
Old 11-15-2004, 10:27 PM
ocuyler ocuyler is offline
Alan,
That's a good question. My guess is that's it's a pair of 2 x 6's, but respectfully, would rather not cut the carpet to find out. To get the taper to fit the hull, it's easier to get the angle with a table saw on a 2x. That's a tough rip on a 4x6.
By the way, the bunk on the 20 is a 2 x 4 on the flat...
Otto
Old 11-15-2004, 10:50 PM
Ya'know, I didn't even think of the angle of the bunk - lengthwise - I'm glad you mentioned it. What angle would that be, approximately ?
I think, whatever the angle of the hull is there, should mirror the angle that would need to be cut into the bunk ?
Any ideas ?
Old 11-16-2004, 11:20 AM
Sorry for all the details I need. Your bunks - are they 8", because they sure look bigger than 6" ?
And, the pix does not show it, but does the bunk sit directly on top of the trailer cross member, or is elevated from the trailer and held in place by the galvanized bracket ? Are there two brackets sandwiching the bunks in place, or just the one ?
I will be copying your set-up exactly, that's why I need to be so precise. I have no other comparison.
Thx,
Alan
Old 11-16-2004, 12:08 PM
Alan,
Yes, you're right, the bunks are 8" and appear to be one piece of wood. I don't know the angle of the middle step of the 23' hull. Somebody help me out here. Here are a couple more images that should answer you questions.
I'll be pleased to pull the boat out into some daylight and take better images of this set-up, if you wish and I'll email a bunch of high-res.
I have to make one comment here. After crawling under the trailer to get these images, you really can appreciate the design and how awesome these hulls really are. I am so thankful...
Otto
Old 11-16-2004, 07:16 PM
Otto,
THANK YOU ! My trailer is a P.O.S. compared to yours. Hopefully with a little work, my trailer will function properly and be useful the 2x times a year I need it.
Thx for those pix. The one showing the left bunk says it all for me! Got it!
Old 11-29-2004, 08:26 PM
bjfg144 bjfg144 is offline
My question is I've seen 4X6 bunks on trailers and rollers on trailers instead of bunks. Which is better in the long run? Is it a matter of personal preference? Or what you can afford at the time?
John
John
