Old 02-27-2005, 08:17 PM
Mark Mark is offline
Default Re: Hull Changes
Bigshrimpin, some of us really want to see a duck-blind Styro-Craft!
Yes, he will need the all important Seamark bracket and HDS sticker too!
Old 02-27-2005, 08:22 PM
Yo Sam
I thought I could add stirofoam
under the boat like we put on the duck blins so it
will float better. I hope more people say things
to help me.
Come on man, Keep the SeaCraft in the shed and build your own crabber!!
Old 02-27-2005, 08:24 PM
Who would have thunk when I woke up today to do my taxes that I would have this much fun?! Thank You ClassicSeaCraft.com!
Old 02-27-2005, 09:07 PM
SEAFARI SEAFARI is offline
Sam, Please send us some pics of your project!! We will have to show them to Mr Potter!
I would really look for a flat bottom boat before you cut up
a Seacraft. I would hate to see you kill a great boat. It was never ment to be a shallow water hull.
Rodney
Old 02-28-2005, 07:43 AM
RS RS is offline
The more you cut from the rear, the greater the transom deadrise becomes. So you probably won't get more draft and you'll have a boat that rocks easily. I suspect Grandpa will be turning in his grave if you try this.
To get a few more inches of draft consider replacing the probably waterlogged floor, transom and stringer foam. Then get the smallest lightest two stroke that will push that thing.
Best regards,
Roger
1979, 20' Master Angler
Old 02-28-2005, 08:35 AM
ocuyler ocuyler is offline
One of our members, Finster, is an expert at adding flotation to 23' SeaCrafts. You may consider contacting him for advice.
Otto
Old 02-28-2005, 09:40 AM
Another member, LT DAN, is reputedly pretty good with a chain saw...
Old 02-28-2005, 11:03 AM
pogden pogden is offline
Worry less, Fish more!
Old 02-28-2005, 11:10 AM
Mark - good one. He'll have it cut down in no time. And don't worry about the fuel tank. He'll cut that in half to reduce the weight. I think you could probably make 2 cuts and remove about 6' from the middle and glass her back together. As long as you maintain that classic SeaCraft arched transom...
Otto
Old 02-28-2005, 12:24 PM
That's a good suggestion Otto: sort of a cut-n-paste approach to SeaCraft reduction. Then, any member that had a 20' and wanted a 23' could purchase the now-removed section and paste it into his/her boat to acheive the 23'. Wow, talk about solving two peoples goals with one chain-saw!
This site is just chock full of great information!
