Old 03-24-2006, 05:02 PM
resurrection812 resurrection812 is offline
Default Re: Cabosil Suplier???
This place down by me in Fl has 10 lbs for $61 and change but not sure on shipping. For bonding and fairing I use Arjay 2001 bonding puddy and fairing compound. It is strong and very easy to work with. Warthog are you familiar with it? Here is the link http://www.fiberglassservices.com/index.htm
1972 23 225 Mariner EFI
Old 03-24-2006, 06:28 PM
warthog5 warthog5 is offline
No, All my work is in epoxy.
Old 03-29-2006, 12:55 PM
Bryan A. Bryan A. is offline
Alright, I got my large super bag of aoerosil yesterday. I am looking for good ideas on transfering this stuff. As you know it is very light and gets everywhere. What is the best way to go to smaller containers to work from? The bag has a pour spot which works but you still lose some.
Another question. What is the best way to mix up larger batches of Epoxy and Cabosil? My hand is getting tired, (Finster I don't want to hear it) from mixing this stuff.
I have seen people use a drill, but with what kind of attacment? And a mixing container with a hole in the top.
Thanks in advance.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 03-29-2006, 01:27 PM
And now you know why I pretty much quite using it.
You must mix your epoxy first. minum of 3min of stiring. You have now induced air into the the epoxy. then you start adding the cabisol at small rates to get the consisity that you want. Another 3,4 or 5min of stirring.
At the dollar store you will find large tupperware container's to store the stuff in.
Old 03-29-2006, 09:39 PM
Ntrain2k Ntrain2k is offline
Thanks in advance.
I always used a drill and a mixer like what comes with the 2 part foam kits. It seems to work great.
Old 03-30-2006, 09:31 AM
Thanks guys, I am very familiar with how to mix epoxy. I have my own reasons for using it on this project. Just looking to streamline the process.
I like the idea about the tuperware, I am thinking of one of those large cereal containers with the lid and spout, that should do the trick.
Ntrain2K - any pics of what you are talking about. What is it shaped like? Is it easy to clean? I was thinking about bending up some 1/4" rod and see how that works. Just need to come up with a shape.
Parker 2530 DVEC
Old 03-30-2006, 11:41 AM
That would be fine, but I was thinking of several container's that were 8in to 9in high X 14in or so X 24in long.
You can just pop the lid and just use a 16oz Dixie cup to scoop some out.
By the way a little goes a long way in thickening. I goes much farther than microballon's.
Old 03-30-2006, 09:25 PM
It's like this, but the end is metal instead of plastic.
I just let it sit in a bucket of acetone overnite and the foam mix just peels most of the way off. They are cheap enough to toss after several uses. Here is a link to an all metal one.
Metal mixer
Old 04-02-2006, 09:21 PM
I was thinking about foam on the clean up I mentioned above.. [img]/forum/images/graemlins/tongue.gif[/img] [img]/forum/images/graemlins/tongue.gif[/img]
When I mixed up cabosil and resin I would use a stuck and scrape of the extra that is in the mixer, then stick the mixer down in a big can and hit the trigger in the drill. The spinning takes the majority of it off. Then a good cleaning with a rad and acetone gets the rest.
Old 04-05-2006, 12:03 PM
rgfettz rgfettz is offline
For mixing large quantities of Cabosil, I went to Home Depot and purchesed 1 & 2 gallon plastic buckets with lids. I cut a small hole in the lid to accept my paint mixer. This keep the dust inside the bucket and got pretty good consistancy.
Fettz
