Old 10-15-2006, 08:56 PM
bj bj is offline
Default Re: 21 vs. 23 Opinions
I have a 2003 21'and have owned a 1977 23' Sceptre and also a 1969 20' CC. Like others have said the 21 seems like a 23 with 2 feet chopped off. It rides extremely well and feels like a much bigger boat than the 20 did. The 20 cc is a small 20 and and at the time I had it it was the perfect boat for both offshore and inshore. It was easy to trailer and to handle. For it's size it rides better than other comparable boats. The 21 is a fairly big 21 and along with that comes the need for more HP and tow vehicle, not to mention more fuel. I would love to have gotten a 23 but it was too much boat for me at the time. Now since I have the 21, I don't think I would consider moving up to the 23 because there is not all that much difference between them.
Old 10-15-2006, 09:32 PM
RS RS is offline
Peter - the real question is, "is that sweet 20 you just redid going to be for sale or is is already spoken for?"
Best regards,
Roger
1979, 20' Master Angler
Old 10-16-2006, 10:03 AM
If you got a SeaCraft you got a good boat. Both boats are designed well for what they are. BUT there is a difference that I see which is the ability to handle sea conditions. Now I know we all have preferences and I don’t want to say something based on my predigest although some one said there is no such thing as objectivity just varying degrees of subjectivity. That being said I think that if you are going to stay in the bay or go out a limited distance “light off shore” the 21’ is fine but if you have a desire to travel a little further into the ocean the 23’ is the way to go plus if you want 3 or 4 people on the boat the 23’ would be a better choice. Although the 23’ isn’t really that big either it does have more ability to stay on a plain going into 1-3 or 2-4 footers Stretching a little longer over to the next wave. Where as the 21 footer bow is going to go down just as the next wave is coming up to meet you. This is not a design problem it is a length of boat to span of wave problem. So the real question is What are you going to use it for and then go with the one that does that job the best.
FellowShip
My motto: Just for the Grins
Old 10-16-2006, 11:29 AM
nestorpr nestorpr is offline
To add to Fellow-Ship's response, the 23 has more deadrise than the 21 and is a better offshore hull. However, the 23 can't go into shallower areas like the 21 can so like he said, it depends on what its major use will be.
Boatless again!
Old 10-16-2006, 12:24 PM
HannahB HannahB is offline
I run a 21. It is not a "classic" and as far as I know it was not put into production until 1998. It has the same deadrise as the 23 according to all the brichure-ware. Mine is a '98 and is paried with a 225. I think it does alot of things well, and as was mentioned earlier it feels big for a 21'. I have not been excluded by WX conditions that would be suitable for the 23', but I have had to go slower than a 23' might have been able to go in those conditions. As also mentioned, wave period and hull-span will be an issue for any length boat in the wrong conditions. I was way offshore when the WX turned snotty one day with a 21' Regulator buddy boat and the Seacraft was much drier with the correct trim/tilt and tab positions. The 21' reg is a nice boat too, but the seas were just bad enough to make their crew wet, and keep us dry on that day.
What I don't like about my 21':
1. Bilge hatch & access to the bilge in the engine well. Poor design & crappy armstrong deckplate that I have re-ordered 2X and still can't get to fit right.
2. In-deck live well (fills with water when it rains)
3. The outflows for my 2 bilge pumps & the livewell are basically at water level
This boat does enough things really well that I will most likely keep the boat, re-finish the bottom and re-power. Interested to hear if anyone has bracketed a 21 and what those results have been like. Good Luck.
Old 10-16-2006, 04:29 PM
Reading several of the replies, it's obvious that many are still comparing the 20' to the 23'. The subject is the TWENTY ONE, which has:
-the exact same deadrise as the 23'
-one single inch less draft than the 23'
-and is only 400#s different in weight than the 23'.
I think most who have not taken a ride on a sloppy day in a 21' (not a 20', a 21') would be quite impressed. I don't own a 21', never have. However, I do own a 20' and know from experience that there is a very big difference between the 20' and 21'....not so in the case of the 21'/23'.
Old 10-17-2006, 09:19 AM
alarie alarie is offline
Great feedback, all. I have enough info to at least go for a ride in the 21 and see what I think. If the ride is similar to the 23 (and I think it is based on what I read here) then it may be the boat for me. It will live on the trailer 90% of the time, which is why I hesitate to go right up to the 23. I use the boat on Narragansett Bay out to Block Island and Cuttyhunk, well within the range of this size boat or the 20 for that matter, it is just a matter of ride.
I have spent probably 25 days fishing in a 23, and I always come away impressed.
Thanks,
Peter
Peter Alarie
"that won't take too long, will it?"
alarie404@mac.com
