Old 11-21-2006, 12:27 PM
ThePHNX ThePHNX is offline
Default Re: What kinds of engine instruments are on your b
How are they computing fuel flow, what inputs?
These the ones made in NZ?
What happened to the old one?
Old 11-21-2006, 07:55 PM
I have to say that the smartcraft calc'ed fuel use is dead on for the injected mercs. On several offshore trips where I used 80-90 gallons, the indicated fuel used was almost exactly the amount to refill at the pump....with 1-2 gallons for an 80+ gallon fill. It also gives you the instantaneous fuel burn rate. I would think that similar performance could be had on on the gauges of any computer controlled fuel injected engine....since the injections are relatively precise. Interesting for the smartcraft tach and speedo, they both have a fuel burn rate and total used number for display. If you reset one when you fill up, and only reset the other when you start a trip, you can have a total used since fill up and a total for that trip. The guages are independent and keep the info internal to themselves.
Old 11-21-2006, 09:01 PM
PHNX - There is a little ball that spins inside the sender, some sort of sensor counts the number of rotations of that ball and the computer calculates the flow (GPH). I don't know anymore detail than that, but both units were very accurate. The gauge buttons on the interface of the f2100 were different.
Old 11-24-2006, 01:50 PM
Sounds a proper sender to me.
What did the setup cost, who'd you get it from, and did you self-install?
Is the readout both dial and digital?
Thanks, Hope you had a great Thanksgiving, HBH
Old 11-25-2006, 04:12 AM
PHNX - I paid $150 from boaters world for the f2100. I can't remember what I paid for the f41. These units are simple to install . . . just follow the directions. Flowscan is the only unit I know of with a digital and dial readout. My brother had a flowscan for 3 years and the gauge rusted up real badly.
Jim from Boe Marine put in a good word for the Lowrance units. If I get another one . . . I'll probably go with that one.
http://www.lowrance.com/Marine/Products/LMF-200.asp
Old 11-26-2006, 12:54 PM
Wow the Lowrance is some do-it-all display and very compact.
Will check further; but apparently the unit you have does its job well, sometimes a straightforward, do one thing but do it well, is better than try too much multi-purpose units.
Thanks, HBH
BTW Cute story `bout instruments; the local pro fisherman - boats that catch $500,000.00 tournament prizes in two million dollar boats - laugh at the term "FishFinder" no such thing they'll admonish, it's a sounder sonny!-)
