Cap'n Chuck, I absolve you in nomine Patri, et Filius, et Spiritu Sancti.
Darlene, another way, besides using the hand pump, is to drill a 3/4" drain hole, mix up a tiny bit of resin to seal the fibers at the edge of the hole, and then stick a live-well plug in it. When the boat's out of the water, just pull the plug and drain it into the bilge. I did this for a friend in a 17' Cruise Boat CC back in the mid 80's. It worked great. He used the little locker to keep his snorkeling gear in.
Common Sense is learning from your mistakes. Wisdom is learning from the other guy's mistakes. Fr. Frank says: Jesus liked fishing, too. He even walked on water to get to the boat! Currently without a SeaCraft ![]() (2) Pompano 12' fishing kayaks '73 Cobia 18' prototype "Casting Skiff", 70hp Mercury |
On my 18 that was the live baitwell, thru hull and seacock in the bottom and a drain out to the transom.
Any way you measure it - dumbass is expensive |
