Old 03-17-2007, 06:51 PM
hermco hermco is offline
Default Re: Fiberglass repair/finishing Deck coat
Good advice for Fiberglassman and all who are considering using US Paints Awlgrip or any of the US Paints products, the manual is a must.
get a US paints Awlgrip manuel and study it
Old 03-17-2007, 10:00 PM
joseeli8797 joseeli8797 is offline
Thanks again fiberglass man...
the first sanding...is that to rmove all old gelcoat or just to scuff the surface?
The 100 grit is to smooth out inperfections and give a coarse surface for Awlgrip primer to bond.
www.fiberglassman.com
Old 03-31-2007, 08:57 AM
If your going to spray without primeing just use 220 grit sand paper,wipe down and spray.
Old 03-31-2007, 04:48 PM
EagleOCNJ EagleOCNJ is offline
Dont you have to prime over going over gelcote or one part paints? You dont have to if your going over two part paints or primers - right?
Ive read the directions ten times but its alot clearer from the glass - man!
Old 03-31-2007, 11:42 PM
If the surface you are going to paint on is flawless no pinholes, no excessive oxidation, no cracks just clean discolored gelcoat even if it has scratches you can fill the scratches and paint over without priming, but you still will need three coats of paint just like painting over primer. The pourpose of the primer is just not for the paint to stick to hull it also provides a built up uniform surface that actualy helps bring out the inperfections in the hull, I use Awlgrip almost on a daily basis,and I always primer any surface first, but if your on a tight budget it can be done. I hope any of this helps good luck.
Old 04-04-2007, 05:11 PM
RingLeader RingLeader is offline
As said above. Awlgrip is expensive stuff and a pain in the azz to strip off and do over. Spend the extra $200 and buy some 545 primer. You'll be glad you did.
Old 04-14-2007, 05:24 PM
It's only money
