Old 06-10-2007, 10:05 AM
Default Re: Installing a bracket
Capt_chiuck....that's a sweet setup. Does that drain out the transom through a garboard plug of is it plumbed out the side via a macerator???? That's a new addition to my "plan"...
Old 06-10-2007, 12:42 PM
bayouboy
The Armstrong water tight hatch allows better access to my bilge pumps and float switches.
Thru hull under the Armstrong is plumbed to a macerator out thru the side.
The small screw & lift drain at the bottom of the box, drains the last bit of water that might remain into the bilge.
Old 06-10-2007, 01:28 PM
Cool...thanks.
It your boat awlgrip or gel coat on the inside. Your deck and inside looks great!!!
Old 06-10-2007, 07:18 PM
warthog5 warthog5 is offline
Maybe this will help?
http://www.dadmarine.com/doc.htm
Old 06-17-2007, 10:25 PM
JohnB JohnB is offline
Capt Chuck,
Thanks for the picture. Can you give me the rough demensions of the fish box. Also, did you insulate it? and if so, how?
JohnB / 23' SeaCraft
