Old 06-20-2007, 05:06 PM
Default Re: Prop for 250 2 stroke Yami
Absolutely stick with the stern-lifter. I suggest the 15.5"D x 17"P Mirage Plus or the 15.25"D x 17"P SWS Yammie, or the 4-blade 15.25X17 PowerTech UN200. All have heavy blades, and near-circumferential cupping, which is good to have in rough water, or when nearly surfacing the prop. The Mirage is about $500, the Yamaha is about $25 less, and the PowerTech is about $675.
Michigan makes a SS 4 blade stern-lifter in a 14.375"D X 18"P that lists for about $300 I don't know how well it compares to the others, though.
Old 06-21-2007, 09:38 PM
thedink9 thedink9 is offline
Fr. Frank
since I have a 15.25 x 19 Yami Saltwater series now, can I get it re- pitched to a 17??
Old 06-21-2007, 09:46 PM
Dink - Use ebay or swap with someone else on THT.
Old 06-22-2007, 12:20 AM
Fishjack Fishjack is offline
Dink - the best option would be a factory original but any "good" prop shop can usually change the pitch of a S.S. prop by one step (2") either direction (higher or lower)..
I have had pitch changes made on several props and worked find..
Good luck..
1977 23' Superfish
ST250x Yam
Old 06-22-2007, 02:42 AM
You'll probably make some money switching from that prop to a 17 mirage plus on ebay . . . Just thinking out loud.
Old 06-23-2007, 03:25 PM
No. You can repitch a SS prop no more than 1/2" without seriously weakening the blades.
