Old 08-27-2007, 09:38 AM
jobu jobu is offline
Default Bow heavy Sceptre
I now have about 100 hours on my Sceptre and I love it. I do however find it bow heavy. The previous owner had put some iron pellet ballast plates in the back of the boat. I couldn't figure out what they were for. They were incased in glass and then glassed and epoxied right onto the second tare of the hull. The workmanship was so poor and one was actually starting to slide around, so I removed them. They weighed about 150-170lbs. each and I didn't want them to damage anything. Now I realize that they were to help get the bow up. One day I (alone)was running wot at 35mph/gps and walked towards the back and picked up 3mph.
Eventually I will install a bracket and close off the transom...I am hoping this will add some leverege and help with my top end. Also I think it should make the boat run more effecient. I am not sure of the prop size but it gets out of the hole ok so I am thinking it is correct.
Any input on the bracket or helping with current configuration would be helpfull!!
thanks, joe
Old 08-27-2007, 11:24 AM
JohnB JohnB is offline
Default Re: Bow heavy Sceptre
I am not sure without seeing the pictures, but I believe those "weights" where put in from the factory. Mine had them too, ugly, and poorly put in. Mine broke lose, and knocked around some plumbing. I was lucky it didn't knock out one of the seacocks and sink the boat.
I am in the process of closing/bracketing my transom. I am putting a livewell in the back, and converting my in floor live well to a fish box. I am hoping this will help balance the boat. I have a large top (see my avatar), and it is a little nose heavy.
JohnB / 23' SeaCraft
Old 08-27-2007, 11:36 AM
Joe,
My father's '82 Sceptre was a little bow heavy until a few years ago when he did 2 things - repowered and hung the new motor (225hp Yamaha OX66) on a manual jack plate (6" setback) and converted the in-deck bait well area into storage. The combination of the motor/jack plate setup as well as placing the anchor/rode and few other items in the new storage area did away with the bow down attitude.
Old 08-29-2007, 12:05 AM
edloh edloh is offline
hello guys,
Is this issue only on the later Sceptre? I have a 77 model and had only been on it once, it is now being restored. I don't have and weight ballast in mine.
Old 08-29-2007, 08:50 AM
Not sure...mine weere about 8"wide 4"high and 22"long. They were wrapped in pale blue fiberglass and mounted to the bottom of the hull, one on each side.
Old 08-29-2007, 10:09 AM
abl1111 abl1111 is offline
Further clarification: outboards only ? My i/o seems balanced pretty well.
Old 08-30-2007, 08:12 AM
It seems to be on outboards...i don't think they would fit next to an i/o.
