Old 06-04-2008, 03:04 PM
76Red18 76Red18 is offline
Default Re: Transducer placement location 20cc?
I have heard you can't change the cable length but you could fix a cut in the cable by soldering the splice. My furuno cable was damaged so I made a clean cut, soldered and heat shrinked all 5 wires and then coated it with liquidlectric tape and all is fine.
J. M. Hendrix
Old 06-04-2008, 03:05 PM
gordonhg gordonhg is offline
I didn't cut my cable. When it was on the transom I ran it through the wiring duct from the console to the transome bilge then ran the wire out the engine cable exit and over the transom. (Actually had to run it the opposite way but same path). With the way I have it now I did not cut the cable either.. it is out of the way, no wires over the transom, no extra holes anywhere. Except the now unused screw holes in the transom to hold the transducer mount that I will now seal up.
Humminbird shows a special way to "coil" up the slack cable. Don't cut it..
Old 05-20-2009, 04:00 PM
mnwnvc mnwnvc is offline
Kbay,
Am I correct in assuming you are using a transom mount transducer in the peanut jar?
