Old 01-12-2009, 11:46 AM
Trayder Trayder is offline
Velvet Jones
Default Re: New2Me 197_ SC20SF
if you can determine the stringer layout that would help. My 69 and I think some 70's had 4 thin stringers where as later years had 2 huge stringers.
Old 01-12-2009, 12:48 PM
I used to have a '70 CC. 2 teak hatches forward, raised forward deck, no vents, no rail, same emblem on the coaming, scuppers down through the deck/hull, 4 stringers, no rear live-well/fish box, transom cutout for twin OBs, and about a 45 gallon fuel tank below the deck.
That oughta confuse the issue.
Old 01-12-2009, 01:00 PM
reelclassic20sf reelclassic20sf is offline
Welllll if i thought i was confused before...now i'm really confused as to what model year i have, but i have some givens that might point me in the right direction.
I will take Trayder's advice and check the stringer layout.
Also i think i can narrow it down to the 69-70's range if those model years had their rod storage more towards midships than others. My confusion might also be options that were added to it that might make deciphering the correct model year a bit harder. But thanks for all your help......i'll be posting regularly to show you all what im doing!!
Contruxi Navis Contruxi Mundus – He who Builds Ships Builds Worlds ...Tight Lines!
Old 01-12-2009, 09:16 PM
Stringers also changed from 4 to 2 in 74(ish). Also in 74 an in floor livewell and underdeck tank were standard(?).
sorry but i have to confuse you some more. my 73 has 2 big stringers and the livewell too.
Old 01-12-2009, 09:49 PM
When you say "big" stringers, what exactly do you mean? The reason i ask is if you notice the last picture i posted showing the interior of the transom you will notice that the deck basically sits on two massive "stringers" that go all the way fwd. I thought this might have been the previous owners redo attempt. I will have to investigate a bit more though.
Old 01-12-2009, 10:09 PM
ill get you some pics of mine tomorrow from inside the rear hatches.
Old 01-12-2009, 10:10 PM
Ima believing it is circa 1970, I have the exact same boat, my fuel tank is mounted above deck, under the console, I have the same hatchs in the bow, same rod lockers, same everything, the aft portion was the engine well, which your guy cut out, I have before and after pictures of mine if you wish to look, let me know. After I'm done with my refit I was going to post the whole job.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 01-12-2009, 10:12 PM
Mine had foam floated back there between the stringer and the outboard hullside.
1974 40' Eagle
www.parkeryacht.com
Old 01-13-2009, 02:10 PM
Was looking through past post on THT and found a Seacraft post....one of the pictures was of a 1969 I/O 20 with the engine box visible.......it seems to be located pretty close to where the cutout on my boat is.........so i'm pretty positive mine was an I/O in one time of it's life. Buying a classic boat that you have always admired is like being a kid in a candy store......so excuse me if i seem a bit overexcited........but then again thats what this forum is all about!!!
BTW didn't know if i could post the pic.....so heres the link:
http://www.thehulltruth.com/forums/t...rt=41&posts=59
Old 01-13-2009, 06:18 PM
Dilligaf Dilligaf is offline
i dont know much but last pic makes me wanna think it was an i/o turned to an o/b. then again what do i know lol
