Old 02-28-2009, 05:28 AM
Default Re: Performance on a 20cc with a 200 Yamaha ox66
When I first seatrial my 20cc w/ DF140 Suzuki after putting on the bracket, I was running a 20" pitch Power Tech prop and hit 47 kts- 54 mph. Light load with two people, and it was chine walking The hole shot sucked, and only turning 5000 rpm. I now run a 18P prop because I wanted a decent hole shot with heavy loads (30 gal bait well, or full load of scuba gear/tanks). Tops out at 40 mph @ 6000 rpm. I may be a little under proped, but for Sebastian Inlet, I really wanted some low end "get up and go".
Lloyd
http://www.go-fast.com/Prop_Slip_Calculator.htm
2.38ratio
20 pitch prop
5000 rpm
= 40mph with no slip
Old 02-28-2009, 12:57 PM
Thanks for the prop calculator, and keeping me honest.
I miss spoke on my early post. I meant 5500 rpm.
I know the number still don't match, but I remember my GPS hitting 47 Kts (I always keep my GPS set to knots). Of course, that was 6 years ago, and I'm doing this from memory .
My boat was very light, I was still putting in back together, no windshield, no bench seat, and very little fuel.
With that 20P Powertech Prop, it was slow to get on plane, and at WOT, I had the motor trimmed way up. I only stayed at that speed for about 5 secs because the squirliness I felt made me uneasy. I made another run at WOT, and had the same result. I definitely remember thinking that this hull was not meant to go that fast
I traded the 20P for a 19P the next day, still didn't like the hole shot, and ended up with the 18P I run now.
That's my story, amd I'm sticking to it
Lloyd
Old 02-28-2009, 02:21 PM
clb33fyxj clb33fyxj is offline
Mercury site has a calculator too...
http://appcenter.mercurymarine.com/propSelector/home.do
1978 Seacraft 18
Old 03-01-2009, 12:11 PM
6000 (rpm) 18 (pitch)
----- X -------- X (1-10%) (avg.slip) = 38.7 mph
2.38 (ratio) 1056 (constant)
Old 03-01-2009, 01:11 PM
I think your gear ratio is too low - I think my Merc is 1.87/1
Old 03-01-2009, 02:44 PM
new 140 Zukes are 2.59:1
older 140 zukes were 2.38:1
Merc 175/200 v6 fishing motor are 1:87
Some Merc sportmaster lowers came with 1.62 gears
I believe I read somewhere that Merc 3:0L gears will fit into a 2.5L case, but I never tried it.
Old 03-02-2009, 09:04 AM
The GLM catalog lists aftermarket Mercury outboard gears available in 1.5, 1.62, 1.65, 1.75, 1.84, 1.87, 1.92, 1.98, 2.0, 2.06, and 2.3:1, with the 1.5 available only for large 4.75" gearcases, and the 2.3 available only for the 4"/4.25" gearcase. These are not, however, the gears available for the Sportmaster. Those are different gear types. I didn't look at those. The GLM catalog doesn't list prices, just part numbers.
Mercury sells gears for the 4.75" gearcase in 1.5, 1.62, 1.65, 1.75, 1.87, and 1.98:1 ratios,
and for the 4"/4.25" gearcase all of those up to 1.65:1, plus the 2.06:1 and 2.3:1 gearsets, according to my Mercury parts DVD. (And WOW are they expensive from Mercury at about $1000 for a complete set!!!!)
Old 03-02-2009, 10:31 PM
Did you guys go off on a Merc tangent for some reason when I was sleeping? I'm running a Yami, but will raise the engine a notch this week and will run this w/e, will let you know the results.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 03-03-2009, 08:53 AM
Nah. That was about gear ratios, regardless of make.
Old 03-03-2009, 09:23 PM
Well you know the old saying...
Once you go black... ..agh, never mind.
See ya, Ken
