Old 03-08-2009, 03:05 AM
GradySailfish GradySailfish is offline
Default Re: Re-Powering my 20 footer MA
I have a 78 20 MA and she's powered by a 150 ETEC. I top out at a little over 40 MPH, but I need to tweak my prop. Currently I'm turning a 14 x 19 3 blade stainless wheel. I think I'm going to try some props suggested by Bushwacker.
Speaking of Bushwacker, he has a 20 Seafari with 150 ETEC and hung on a bracket. He ghets top ends in the middle to upper 40's. I hope he chimes in here.
As for overall performance of the engine, I'll just say right out that its outstanding. I only have half of one season on the engine, but I'm impressed so far. Fuel efficiency, holeshot, etc are all excellent. You don't need 200 HP for that boat, honestly if the 130 ETEC was around when I was putting new power on I would have gone with the 130.
I normally cruise at 3300, which yeilds a speed of about 22 knots and fuel milage of about 4 Nautical (or 5 statute) miles per gallon.
If you have any questions please feel free to PM me.
-Alex
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
Old 03-08-2009, 09:59 AM
i still gotta check that boat out.
i have a 200 merc on mine. it doesnt seem to be really too stern heavy. i dont have a bracket either. my motor is just an old 2 stroke which is probably why its lighter.
Old 03-09-2009, 10:23 PM
ROBCAR ROBCAR is offline
Great info...and thanks to all for your comments.
Based of what I know now, I think I will very likely go with the 150 hp. Etec seems to be the winner because of its simplicity (compare to a 4 stroke), weight and performance.
....Now, if I could just find one at a good price (2008 model).....I am just dying to get the engine and put the boat in the water. It does look really good after the paint job "Lady Fighting Yellow with White and black stripes"
Old 03-11-2009, 12:46 PM
zach zach is offline
I think you're making the right choice, any DI 150-200 hp is a great match for this hull. You'll love the torque, hole shot, efficiency, etc. I think e-tec builds a 200 from the same block as its 150. Personally, for the same weight, I'd go with more power. With that being said, a 150 is plenty.
Post the pics!
Old 03-11-2009, 07:28 PM
Call this guy on a motor - he also has some other Etec's from '07 I think but worth a call at least. An FS memeber called every dealer and he was best. Mike @ American Marine 727 938 9796 and be sure to tell him where your from here, BRP is very touchy about dealers quoting prices on the phone.
Old 03-12-2009, 01:21 AM
Alex, I would have chimed in sooner but I just got back from a 4 day cruise in the Seafari! Me and an old buddy that I grew up with spent 4 days and 3 nights on the boat exploring the St. John's River from Sanford to Palatka and back. Ran 236 miles (per GPS) and burned 55.3 gal for an average of 4.3 mpg overall, loaded VERY heavy, about 3800 lbs total load. For this trip I switched to a lower pitch prop, a 4B 15x15 Powertech, which would turn about 5400 with this load. Top speed was only about 38 with this setup and heavy load but it was a bear on holeshot! The I-command gages show % of full throttle opening and I never had to use more than about 50% to easily get on plane! Optimum cruise was about 3600-3700 at 35-36% throttle at about 26-27 mph and 3.8-3.9 mpg. Overall mpg is higher because low speed mileage is in the 8-12 mpg range. (The E-Tec's beat ALL other motors, 4-strokes included, below 2000 rpm because they run so lean in that speed range. This is significant - most folks don't realize how much time they spend at low speed!)
Weight has a significant impact on performance, and this same rig with just me, a full tank of gas, and the big bimini top folded has run 49.8 MPH (gps) with my 4B 14 1/8 x 20" Michigan Apollo; optimum cruise in this configuration is around 3200-3300 rpm/25-26 mph and about 5 mpg! However that prop will only turn about 5000 with the sort of load I had on this trip, and I felt it would lug the motor too much.
The "150" is actually about 165 by BRP's own brochures, so it is definitely plenty of power for the 20, especially the CC's and MA's, which should be a couple of hundred pounds lighter than the Seafari. I probably would have bought a 115 E-Tec if they had been available when I repowered, since I ran this boat for over 30 years with a 1975 "115" (about 90 hp at the prop!). After this trip however, I'm glad I went with the V-6 . . . it's also a little smoother than the V-4 at low speed.
I also agree that 50 mph is about the practical limit for the 20' hull unless you put way more than 150 hp on it, and then you get into balance and CG issues with heavy engines. I bought mine from Brown & Hauptner Marine - Frank Brown and Mark Hauptner knew as much as anyone about making a boat go fast. Frank crewed for Moesly on the racing 21's and Mark raced hydros since he was a kid. Hauptner had a Seafari with an old I-6 Merc that would run about 50, but it was definitely "tweaked", and he told me it was really hard to get that hull much over 50, no matter how much power you put on it, since it really wasn't designed for "speed at all costs". Denny
Old 03-12-2009, 01:26 AM
The 150 is fine, if you get a deal on something bigger take it -they all weigh the same its $$$ now, thats why I said call Mike
Old 03-12-2009, 02:14 AM
Thank you guys for such great input...it does really make a difference in my decision, specially when I am about to write a check for approx. 13K (engine, prop, cables, installation...etc)
Egg, I will for sure give Mike a call, hopping that he would have some last year special or a particular deal on a demo engine. And you said before, at this point its all about the $$$$$....given that I want that 150 hp E-TEC installed and ready to go ASAP.
I will soon post some pictures of the whole rebuild, which I hope would include the new engine.
Old 03-12-2009, 06:38 AM
I'm up here in Lauderdale, give Joel's outboard a call, ask for Joel, 954 763 7745, he might have something, I could introduce you guys, he is a good guy, be around a long time.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 03-12-2009, 10:32 AM
Good info Caymanboy. Will call Joel this morning and see what he has in stock...thanks
