Old 07-25-2009, 04:21 PM
BigLew BigLew is offline
Default Re: Downrigger install?
It's the same setup as mine.
If I are going to mount down Riggers on mine, I would install a hawes pipe just aft of the rodholder on the gunnel. Then I would glass in underneath three 10" 8/4 x2-3" white oak strips laminated face to face so that the edge grain was facing up under the riggers and through bolt the rigger mounts to those where the cleat is now.
That said, I would also check with someone who I trusted in such matters. Some serious aluminum plate maybe all they'd recommend. My thinking is torn fiberglass is much more expensive and inconvenient to repair than using a little overkill to begin with.
Just my 2 cents.
Plan accordingly!
Old 07-25-2009, 11:08 PM
Mine go in the 2 rear most rod holders.
Old 07-26-2009, 08:50 AM
Here is a picture of the transom. hopefully it will work!
Here you go...
Old 07-26-2009, 09:07 AM
Rlbol Rlbol is offline
I did see mounts that are made for the rod holders. How do those work? Are the secure in there and not to much pressure on the rod holder? Do you run yours off the side or straight back?
Old 07-26-2009, 09:09 AM
Thanks IslandTrader
Any idea of what i did wrong?
Here you go...
Old 07-26-2009, 11:10 AM
Thanks IslandTrader
Here you go...
Go to your photo bucket. Click on direct link of any picture and copy it.
Come back to CSC...post reply, click on image and paste the direct link, and it should appear.
Old 07-26-2009, 08:25 PM
Typically off the side. I installed 1/4" aluminum backing plates on the rod holders. I've never had any problems. I like the clean, flat cap look.
Old 07-27-2009, 09:10 AM
Thank you Reelescape
If it is not to much trouble and when you have a chance, could you take some pictures of where the hawspipe is installed as well as were and how the cleat is installed below the gunnel? I also love the clean cap look . I also love how the hawspipe looks. Like a big sport fish. I a not sure if my boat was ever set up like that or not.
