Old 01-27-2010, 12:15 AM
horseman horseman is offline
Default Re: Pictures of the new boat EMANON
Good luck. She is a beauty
http://i766.photobucket.com/albums/x.../Seacraft3.jpg
Old 01-27-2010, 09:53 AM
thanks for the extra pics. i have a little teak door on each side that ill probably be replacing with something bigger like yours. id like to have those open up into a dry storage space. ill need to start designing that. does your boat still have the liner in it or was it removed when the floor was done??
GFS, you had a little tackle station in there? that might be a good idea for one side of the console. do you have pics of that tray?
Blue,
I`ll have to get you a pic, or I`ll be in FtL. this sat if all goes well with the trailer work if you want to see it. I put a big hatch in the front of the console so I can put the tackle station back. I like the extra storage too.
Cheers,
GFS
Old 01-27-2010, 12:45 PM
Reelized Reelized is offline
That indirect lighting is great for night fishing.I did my last boat with blue LED.It kept me from using the speader lights as much.Thats one mod that's on the list for my Seafari.
Do you have any pictures of the steering station on the T-top?
Old 01-29-2010, 09:06 AM
trave2 trave2 is offline
When the boat was redone they only replaced the center decks above the fuel tank with new foam core decks (bolt in). The outside deck was in good shape, no soft spots and solid, stringers too. The boat was barn kept in GA for years he said, thats where the previous owner picked it up. Yes at some point the outside decks will need to be redone but I don't see that happening for decades. Even the transom was solid and dry when they raised it 5 in to match the 30in motor. The gelcoat is orig as well, compounding right now! minus the small scratches for a 24 yr boat.
Anyone know the best or easy way to hook up the throttle control for the upper station, cables already run to the console, terminated at the existing binicle, single yamaha binicle? Can I get a dual binicle shift and throttle(side by side) and Plug-n-play? The steering is hooked up and works great.
Also does anyone have a Furuno sounder bbff1 or the new dff1 (black box) they want to get rid of? I have a airmar thru-hull transducer waiting to be hooked up!
Old 01-29-2010, 02:44 PM
fdheld34 fdheld34 is offline
Great looking boat!!!
try the hull truth..post a WTB ad..should get a good response there
Fred
Old 01-29-2010, 05:41 PM
Nothing like that nice, clean wiring. Sure beats my birds nest!
