Old 06-12-2010, 03:54 PM
tri5 tri5 is offline
Default tank install
looking for the best way to install new fuel tank with out useing foam.also what kind of tank to use metal or plastick
Old 06-12-2010, 04:18 PM
Default Re: tank install
aluminum, that is what i used. 95 gallon, usable
Old 06-12-2010, 09:03 PM
BigLew BigLew is offline
You might want to read through this a couple of times. There's a lot of good information.
http://www.yachtsurvey.com/fueltank.htm
Good Luck.
Plan accordingly!
Old 06-12-2010, 09:05 PM
Hey Brandon,
Where abouts in Bristol County are you. I grew up in Taunton. I live in the Newburyport area now. - BigLew
Plan accordingly!
Old 06-13-2010, 09:01 AM
somerset m.a.
Old 06-13-2010, 11:30 AM
castalot castalot is offline
i hope you can make it to the jazz festival on august 7th
i work in swansea if you ever need a hand
Old 06-13-2010, 11:59 AM
yea me too i can run on some plastick tanks if need be.but dont like the tanks on the deck.i think i will have new tank by next week.like to meet some of you guys on the water cheeck out your boats cant miss my fadded out black scepter w/250 etech on it.allways on chan 65 just yell out for the black duck.
Old 06-13-2010, 02:27 PM
adamcannon adamcannon is offline
I have seen several tanks installed on a grid made of rubber hose. The hose went on a platform built on top of the center stringer and around the tank on the sides. I am not sure if this will chaff the tank. Just so the tank doesnt move around it shouldnt chaff a hole in it.
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket
