Old 07-17-2010, 02:14 PM
Default Re: Post 1980 Seacrafts
i guess i will be drilling a few sample holes in my stringers.
Old 07-17-2010, 05:38 PM
I've been in the hull of a '92, and it was all 'glass.
Old 07-17-2010, 07:51 PM
In late 1987, we got in an '87 Tracker SeaCraft 23 WA at Lake Worth Yachting Center, where the transom had been severely damaged in a rear-end collision while being trailered. As part of the repair, the entire transom was removed. I was then shocked to learn that the stringers in that boat were fiberglass-encapsulated plywood, unlike Potter hulls. And though the hull was just one year old, the plywood was already wet and separating inside the stringer.
The WA looks to be an unknown design. I will not defend Tracker`s riggers or cheap hardware. I had a slight delam of about 1 1/2 ft by 4 " of the top layer of the inside of my port stringer , but they are the big box foam stringers of the `72/73 design change on my `89 20.
Did tracker own another boat co. that made the WA and just rebadge it? Ah, the onion.
Blue Heron, where is the hook in your hull?
CSY`s may have been the heaviest, but I bet the Moesly`s were the most consistent.
Cheers,
GFS
Old 07-17-2010, 09:26 PM
My '88 Tracker built 23' WA has foam filled stringers.
Old 07-18-2010, 10:24 AM
I was hoping you would chime in. Any idea who designed it?
Is the family enjoying her?
Cheers,
GFS
Old 07-18-2010, 02:09 PM
JohnB JohnB is offline
That's a first, I have never seen a SeaCraft with wood in the stringers. Maybe the cap on the WA made them have to "adjust" things to make it work. Who knows.
The older these boats get, the more wear and tear there is, so there is a tradeoff with older hulls, although they might of been made better, time and wear causes other problems.
I have crawled around a lot of these boats in FL, and I have seen some manufacture/assembly glitchs in a few, but nothing consistantly wrong/bad across any models/year from about 1989 and back.
I think the only thing I have seen is the attachement of the hull/cap/liner losens up on all of them after 10 or so years of use. The transoms on almost all of them are wet in areas, but these boats were so overengineered/built that most are still safe and servicable.
All the rigging and wiring dropped off fast in the late 80's but that seems to be the way of the industry.
The design and ride are pretty consistant across all years. I believe the late 80's boats are heavier than most other years. T
JohnB / 23' SeaCraft
Old 07-18-2010, 09:47 PM
I have no idea who designed the top sides. The plaque, and from what research I did before I bought the 23WA said it was built by Tracker in Tampa, FL. It's not the best layout, but it's a walkaround, and it's a Seacraft hull, just what I wanted.
Yes, the family loves the boat, but the Merc blew at the end of last summer, and now it's a project boat. I got a sweet deal on a used Suzuki 250 4S w/ only 135hrs from a friend who upgraded to a 300hp. I'm in the mist of replacing the fuel tank, transom, wiring, etc (the usual suspects in any boat over 20 years old), and we all know how projects go. It's especially slow since I'm running a yacht 1000 miles away from home.
But we get out in 20SF as often as we can (BTW, this eats into project time, but it's worth every second )
Lloyd
Old 07-19-2010, 09:43 AM
Lloyd
Hot up there eh?
The topsides of that era were more function than form. Does she ride nicely?
Every minuite on the ocean is bonus time. The work to get there just makes it a little sweeter.
Cheers,
GFS
Old 07-19-2010, 10:40 AM
She rides GREAT!!!!
Old 07-20-2010, 09:43 AM
Of course she does! They seem to like a little weight forward. Sorry you didn`t hit the Jersey gathering. How`s the big boat and the soft grass treating you? We should think about Long Point for the fall. I was in Melbourne lately and it sure has grown.
Cheers,
GFS
