Old 04-05-2011, 10:18 AM
Wildman Wildman is offline
Default Re: I'm at the tip of the iceberg
I have removed the fish box from in front of the console and slid my fuel tanks up that distance (aprox 24 in) to help with the 'squat'. I am putting he fish box under the leaning post so I dont loose any storage. I am also planning on running an alum 'dual' motor bracket for more flotation.
Old 04-05-2011, 06:38 PM
bridgeman bridgeman is offline
That was my ride...I'll never sell her. The guy who owns the lot is a good egg, lets me park it there for cheap. I've been parking my boats there for decades.
Old 04-07-2011, 05:42 PM
ledslinger ledslinger is offline
Thanks Danny, I wont be needing them for a while yet.
This 23 inboard is one of the jackshafted diesels that was converted to a bracket and outboards. Ive made it past the twin diesel tanks and they are in pretty good shape but i may change a few things and install new. Hopefully I can get the center console off this evening. Its interesting that the transom is foam cored (2-1/4" total thickness)at first I thought it was balsa---in any case, its coming out and 2 layers of 3/4 marine ply going in.
Thanks Mike
"Something is happening but i don't know what it is"......R.A. Zimmerman "Ballad of a Thin Man"
Old 04-14-2011, 11:44 PM
Progress ! Tanks are out--center console is out and stripped all the wiring and attacking the transom. I cut the rear cap with the fish box and bait wells where it was cracked on both sides where the filled in hawes pipes were. A friend has a cnc router and cut a half template of the transom from my autocad drawing. If it looks like a good fit with the template he can cut the 2 sheets of 3/4 marine ply with a phone call . The foam cored transom is being dismantled. The foam was broken off the original outer skin on both sides which probably let the transom move in and out with the twin 225's and i assume cracked the cap at the cockpit corners.
Havin' fun yet?---Looks like some history there!
The original diesel tanks look good except for the steel around the sending units. I'll seal them up and test them to the original 4 psi and try to hold it and check them for a pressure loss in the morning---if they look good i'll get them boiled out and clean them up and reuse them.
Thanks Mike
Old 04-15-2011, 12:01 AM
Floor Skins
Has anyone used Sequentia Fiberglass panels for a floor skin? http://www.fiberglasssheets.com/FRP/...P-Liner-Panels
I don't think my original floor is worth saving. The thickness is .090 and has a pebbled glossy texture (it may be slippery when wet) I laid up a 12" piece with 4 pcs of 3/4 mdo and put on a skin on the bottom of 1708 and West System. I'll try to wet it and see how slippery it is with boat shoes.
Thanks Mike
Old 04-15-2011, 12:27 AM
Welcome to CSC ledslinger!
Single 250hp / Seamark Flotation Bracket, 135 gals Fuel
PM Sent
Old 04-15-2011, 01:32 AM
Capt Chuck,
Sweet looking ride!
Thanks Mike
Old 04-19-2011, 01:55 AM
Minor Setback ! After getting all the foam blocks out of the transom, I started cleaning up around the edges and then I realized that the foam core layer was sitting upon a layer of 1/4" thick Bondo. That probably didn't help with preventing the delamination of the transom. I started removing it in chuncks with a chisel and hammer and ended up sharpening a masonary hammer and taking it out in big pieces rather than turning it all into dust with a grinder. A 2 hr effort got it about 1/2 done.
Does anyone have any suggestions on how to handle all the plugged holes in the outer skin? Some holes were plugged with plywood, others with Bondo and many others with caulk, dowels and silicone. The one thing for sure---there's a lot of them ! [img]/forum/images/graemlins/tongue.gif[/img]
Old 04-19-2011, 08:04 PM
KenB KenB is offline
I am having the same problem with some half-ass repair jobs on mine... I was told to grind everything back to glass, and bevel the old glass. Then repair in layers. first a 2 inch wide strip, then another layer that is slightly bigger (say 3 inches) then 4 inches, etc. until you get back to the original glass thickness. Then grind the surface down to flat.
Old 04-19-2011, 09:57 PM
Hi Ken,
Thats kinda the way i was thinking---i didn't feel right closing up the transom with the wood repair at the bottom---its pretty wet. I used an air chisel on the rest of the filler, it went pretty fast. One more session and i should be filling all the holes.
Thanks Mike
