Old 07-29-2011, 10:00 AM
tri5 tri5 is offline
Default Re: gill bracket ?
hope it will ride better mike. it just seems to me more flotation would make the bow dip foward when baot is still in the water. thats the last thing i want more standing water in the cockpit.maybe i shuold buy that 27' seamaster what a fn boat!
Old 09-24-2011, 09:41 PM
fandtm666 fandtm666 is offline
I have been looking around for measurements on a design for a bracket similar to the single engine Hermco.
does anyone have the measurements by chance because i have read so many different idea's on how much higher
the motor should be mounted once the bracket/pod is installed.I will have a 75-90hp long shaft mounted when done
so the normal mounting would be at 20inch but i am confused as to what height it should be once the pod is mounted.
i have been toying with the idea of building mine to extend 60cm/23inch from the existing transom so i can get some deck space
and add some extra flotation with the added pod.
thanks
666
