Old 08-13-2011, 08:04 PM
Default Trade trailers or rollers for bunks
The 20' hull gives me fits trying to get it lined up on my trailer with rollers. Want to trade rollers for bunks or trade trailers. I have a galvanized dual axle with new (in April) surge brakes and new rollers. Only seen salt once, ad has been dipped in the fresh water river after that.
Old 08-13-2011, 10:28 PM
Default Re: Trade trailers or rollers for bunks
Are you driving on, or winching?
Old 08-14-2011, 10:08 PM
generally, tie up at ramp, run for the pickup/trailer, back down a steep ramp and pull the boat on with the painter. The ramp is too steep to (hand) winch on, I think.
I have a problem with getting it centered on the rollers. Any suggestions?
Old 08-14-2011, 11:41 PM
Most roller trailers work fine if you don't dunk 'em too deep and use a winch. I just barely get the tires wet with my EZ-Loader and I never dunk the axle or springs, which is why it's lasted 25+ years in salt water. Have you considered using a power winch? It greatly simplifies loading if you're by your self. You can also add a pulley to the snap hook and then run cable thru pulley and back to winch stand to double the pulling power of the winch if necessary.
Old 08-15-2011, 08:56 AM
fdheld34 fdheld34 is offline
I agree with Denny (Bushwacker)...I have a roller trailer as well...works good for me because I do not have to back in so far on the steep ramp near my house...makes a difference due to the fact that I now use a Kia Sedona minivan for towing my 20 GW Overnighter..I can pull it out of ramp with ease because I do not have to dunk the trailer..also used a roller trailer on my 20' Seacraft as well with optimum results...I currently have a 2 speed winch which is ok for now...Also the tides really do not affect the roller trailer usage..
Denny has some good pics of proper utilization of a roller trailer that he posted on here..that might change your mind about a swap...I cant find them though
-Fred
Old 08-16-2011, 01:07 AM
-Fred
I've used the same trailer for over 26 years and have gradually refined and improved it's adjustment and usage. I normally load and unload all by myself, no other help required. Here's a slide show of the results at local village ramp I normally use.
One note of caution: When using a trailer of this type, ALWAYS put a chock behind all 4 wheels when loading! (OK to only chock rear wheels when unloading unless it's a really steep ramp.) Reason is that it's not a tilt trailer, and there is a point during loading that ALL the weight of the boat is on the rear X-member, which will lift the rear tires up onto the chocks! They will SLIDE if front tires are not also chocked! (Ask me how I know this! )
