Old 08-19-2011, 01:14 PM
Default Re: Is this a sea craft?
I agree with the multiple pump logic. I boat on a land locked medium sized lake and still have 2 pumps. A Rule 1500 and a Rule 800. Both can be operated with a manual switch. Both are also "hotwired" to the battery through an automatic float switch. JIC I also have a high water alarm. Some people call this overkill, I call it safety! BTW, my boat doesn't take on any water during dockage.
Old 08-19-2011, 01:23 PM
http://files.dnr.state.mn.us/educati...atbuilders.pdf
coast guard regs. for boat builders . . . I believe guidlines are the same for real boat builders. A 2000lb fiberglass boat under water doesn't require 2000lbs of foam floatation to float. see pages 16 - 29.
BASIC FLOTATION. Builders of inboards and inboard-outdrives are required to
comply with the Basic Flotation portion of the Coast Guard Flotation Standard. Basic
Flotation requires a fully loaded boat to float with some portion of the boat above the
surface of the water when it is swamped. This means that the boat must contain
sufficient flotation to support two-fifteenths (2/15) of the persons capacity and 25
percent of the dead weight. Basic Flotation is designed to give the survivors of a
boating accident in which the boat has swamped something on the hull to hang onto.
The advantages of Level Flotation versus Basic Flotation are obvious (see introductory
paragraphs to Level Flotation section).
Builders of boats that are subject to the Basic Flotation requirements should perform
Steps I and II in the “Calculations section on the following pages and substitute 25
percent of their boats’ rated maximum weight capacity for Step III in the appropriate
example. Also, since Basic Flotation requires only that some portion of the boat
remain above the surface of the water, the location for the required amount of flotation
material is unimportant.
Old 08-19-2011, 01:41 PM
Nice link, Big.
Probably ought to get a sticky on this site...
Definitely getting a bookmark from me.
Old 08-19-2011, 01:56 PM
KenB KenB is offline
For a 17' outboard they say 20 cubic feet (or about 5 gallons of uncured foam). For a 20' inboard, they say 22 cubic feet. P. 26 suggests pouring foam down the gunnels.
How much floatation should I add? I assume what is in the stringers is enough to pass the restrictions, but how much is enough to float the boat?
Can we convert that to plain english for 20's and 23's?
Old 08-19-2011, 04:10 PM
OilFieldMan OilFieldMan is offline
Instead of adding foam, I'd be adding extra pumps. The way this boat sank I don't think it'd matter how much floatation foam you had it in, she was going to the ocean floor.
1974 Seacraft 20' SF with 1985 Evinrude 150 VRO
1987 Seacraft 23' Scepter with 2007 250 HP Evinrude Etec
Old 08-19-2011, 05:00 PM
Ken - The formula breaks the equation down to 3 steps. Calculate the foam floatation required for Boat (FB) motor (FM) and People (FPC). To keep it simple we'll not use include any floatation added by coring (like transom plywood, balsa deck, etc).
Boat = 1600 x .33 (fiberglass) + weight of gear on deck (200lbs) = 728lbs/60.4 = 12 cu. ft
Motor = 352lbs (suggested submerged weight) includes battery, controls, etc. (75% of dry weight)
=352lbs/60.4 = 5.82 cu. ft
People = Still not 100% sure on this one. maybe someone can explain this.
18cu. ft of foam is enough to float a rigged 20 seacraft without people on board. If you count the transom wood and the balsa/plywood deck quite a bit less than 18 cu. ft. You can take measurements on the stringers . . . but I would guess that 4 stringers full of dry foam (pre-72 hull) would be more than enough to float that hull with the motor and people. The boat might turtle b/c of stability, but won't sink.
Old 08-19-2011, 09:26 PM
red20 red20 is offline
I think that model was called the sink craft. All kidding aside if you own a Sea Craft and do not run 2+ bilge pumps @ 1500GPH on float switches on separate batteries you need to do so.
Old 08-20-2011, 04:28 PM
TooFly TooFly is offline
So let's say you're 20 miles offshore and taking on enough water to keep both pumps running continuously and for whatever reason, it's taking forever to get back in and your batteries drain completely? Now what?
1969 20' Potter SeaCraft
2007 150hp Evinrude E-TEC
Old 08-20-2011, 04:35 PM
Use a manual bilge pump and if that does work put you head between you knees and kiss your ass good bye, because your going to be turtled
Old 08-20-2011, 07:11 PM
I cant do that any more because my stomach is too big.
