Old 03-21-2012, 08:54 PM
GodsReel GodsReel is offline
what about a change in the angle of the transom?
Old 03-21-2012, 09:16 PM
Originally Posted by Entourage View Post
I don't think so i left about a 2-3 in lip all around and did not change any shape of what i left.
The hull bottom was not disturbed or glassed?
Old 03-21-2012, 09:23 PM
fdheld34 fdheld34 is offline
Sandy...good straightforward questions...stop ....your.. scaring me...!!!!
Your Garmin still works I still know how to get home...pigs fly!
Are you running a chopper?
-Fred
Old 03-21-2012, 09:27 PM
No the hull bottom was not touched.
Old 03-21-2012, 09:29 PM
Again i slid in the new transom from up top into the lip that i left so if there is a change in angle it can't be alot.
Old 03-21-2012, 09:32 PM
The strange thing about this is when i am going along i can trim the motor up and this will go away. The thing is that i have to trim it up a bit to high to run all the time. I like running with motor trimmed up when the water is flat, but when it is choppy i have to bring it down due to cavitation.
Old 03-21-2012, 10:01 PM
Entourage,
BRP says you should be able to SEE the top of the Anti-Ventilation/Cavitation plate when you're up on plane and fully trimmed out. I suspect your motor needs to come up at least 1 hole. As others have said, AV plate about 1" above keel should be about right for a transom mounted motor if you have a good cupped prop that bites well. Denny
Old 03-21-2012, 10:13 PM
-Fred
My fave is the Apollo 4 bl. Bites well. Smooth design on the hub.
This prop made me smile for the lack of "bad" vibrations. I felt a very noticable smooothnesss in my hand.
Far better than a slug of plastic and a bad casting job.
I`m runnin and old sst1 prop now til I sssssssort out another issue.
Spring is here and the cobia are early. Heads up. This is going to be an early year.
86 in Bangor, Me.
80 in WPB.
Cheers,
Us
Old 03-21-2012, 10:31 PM
OK, Sandy stay the coarse.....
A.D.D. is setting in.....
Meds are good, erbs are bad!!
We will over come!!!
Old 03-21-2012, 10:47 PM
Beautiful pilot house. He may benefit from a bow lifter or a 4 blade sliced outside.
Cheers,
Us
