Old 05-06-2012, 10:40 AM
3rdday 3rdday is offline
Default Physical Characteristics DATA
Linear Shrinkage- ASTM D2566 = in/in <0.001
Ultimate Tensile- D412-80= PSI 8000
Modulus of Elasticity- ASTM D790-97= MPA 1896.7
What about shrinkage when curing? I heard this is a problem with Polyester/SeaCast. What about Urethane?
Old 05-06-2012, 11:02 AM
My brother and I used the Arjay product. No shrinkage. Remember what makes this stuff work is it's sandwiched between two layers of glass....the transom's outer and inner skin.....and it bonds them together, forever. In hindsight there are a few things I would do differently, however I'm very confident with my transom job.
Old 05-08-2012, 06:39 PM
hugo hugo is offline
just found i need to do my 20SF transome so i am also intrested! thanks
hugohettinga@yahoo.com
Old 05-08-2012, 08:21 PM
Nobody gives transom like you Don.
Who is gonna start the Abaco thread? Lil` old me or the elders whose toes I choose not to step on.
Where to step,
GFS
Old 05-08-2012, 10:40 PM
Low shrinkage and 8000 psi is great. How well does it bond to other matrials, fiberglass, wood, etc. Does it have a good bonding strength?
Old 05-09-2012, 09:46 AM
Ulf Ulf is offline
I have a '74 20'cc.
Has anyone drilled smallish holes through top of transom and poured resin into transom with any success?
I have some flex in transom, but how much flex is too much? The transom well is still intact.
I'm looking to postpone a full transom redo until my other projects are finished.
Would your product be usefull for this ?
Old 05-12-2012, 01:55 PM
It bonds like "shit to a blanket" it is a urethane and urethanes have great adhesive qualities.
Old 05-12-2012, 01:58 PM
yes the product would work for this but you will have to still dig out all of the rotten wood core, or all of the wood core. With any system, nothing can restore the rotted wood. the wood is rotten because of water infiltration, nothing can displace the water/moisture, as the wood as already absorbed the water.
Old 05-12-2012, 03:22 PM
martin martin is offline
Default transom repair
Well where can I get it and how much ???
Old 05-15-2012, 01:23 PM
Default transom repair polymer
I offer the material and its $ 120 gallon.
