Old 05-04-2012, 10:11 PM
Originally Posted by YeA 20sF View Post
Thanks Blue, so basically the location of the one in the first pic would be the best spot for the new one. When I remove the old ones do I just fill the old holes in with 5200 or should I do something else ?
The location of the original transducer may be a little close to the engine. As Big Lew mentioned, the Garmin installation instructions should give you some guidance on minimum distance. If Garmin says it's ok, you should be good.
On the holes for the old transducer and speed sender, 5200 will work, but if you can drill them out a little and pump some thickened epoxy resin in them that would be a more permanent solution.
Dave
Blue Heron Boat Works
Old 05-19-2012, 12:25 PM
YeA 20sF YeA 20sF is offline
Do I pump in epoxy and thats it or do I pump in epoxy and then 5200 over that ? Going to do the install today
Old 05-19-2012, 01:21 PM
BigLew BigLew is offline
Just fill the holes with epoxy and let them set up. Make sure there are no bubbles and level it the best you can with the surrounding surface makeing sure there are no "low" spots. After it sets up and cures-a couple of days- sand to the surrounding surface and apply finish coats-paint, gelcoat, etc.
Plan accordingly!
Old 05-19-2012, 02:37 PM
get a counter sink bit and get some 30 minute or 60 minute epoxy from home depot and mix it to be like mayo. maybe a little thinner. drill a little counter sink in the holes first then fill the holes as best you can and put masking tape over the holes until dry. it will be sealed for good. you wont need five thousand two hundred for the old holes just the new ones.
Old 05-20-2012, 09:56 PM
Put in some work with my old man today...
Drilling out the old holes in prep for the sealer...
Sealed up some holes and installed the ducer..
Max hanging out in the shade
Vuala, GPS
Also changed put my T-stats on the Merc,they were toast.
Old 05-21-2012, 04:43 AM
Highly recommend a protective screen cover for the head unit. Windex, sunscreen, etc. will permanently stain the screen. I usually get mine from ebay They also minimize scratches from rings and stuff. Be sure and grease the plug pins occasionally
Old 05-21-2012, 10:33 AM
what do you mean stain the screen ?
Old 05-21-2012, 12:13 PM
See here;
http://www.ebay.com/itm/Screen-Prote...item53e57243c5
Today's electronics have a protective coating on the screens. Harsh chemicals including sunscreen will damage it. These protectors also offer mechnical protection; rings, hooks, etc. I'm not pushing the vendor just the concept. I have them on all of mine including I phone.
Old 05-21-2012, 12:35 PM
See here;
Nice i got one on my iPhone as well, didnt know they made these for the Garmin. Will be picking one up. Thanks
Old 05-30-2012, 03:25 PM
So how accurate is the speed reading on one of these things ?
