Old 07-17-2012, 02:56 PM
Cutiger Cutiger is offline
If it's around still when my Shamrock sells I'll be all over it. Just need the cash from my boat first.
Old 07-18-2012, 04:03 PM
REXGEAR REXGEAR is offline
Hey... i am trying to replicate the original switch panel of the 1985 Seacraft... or buy an original one that is in good conditions... i was looking at yours which is exactly what i am looking for... will it be possible for you to give me the dimensions of your switch panel?
Thank you!
Old 07-19-2012, 07:20 AM
mperkins mperkins is offline
Rexgear, if we are talking about this panel, it measures 23" x 3 1/2", it appears to be made of platic engraving stock, approx. 1/16 tk. The thickness of the material you use will be limited by the design of the breakers you install. I believe the ones in this panel are AirPax, the cutout dimensions are, I am sure, listed on their web page. With a dimensioned drawing this panel would be readily produced with a cnc rotary engraving machine, the software may even have a font that is real close. Name:  001.jpg
Old 07-19-2012, 10:03 AM
Thank you so much for the specs on the panel! Ill let you know how close i can replicate it.
Old 07-25-2012, 05:12 PM
Default Can't attach an attachment
Hey guys, I had one prospect this weekend but we couldn't quite get there.
I am trying to post a Word Document as an attachment in this post, but I keep getting an "invalid error". The document has a list of improvements I would like to add to this posting, any help/advice on adding this attachment would be appreciated. thanks John
Old 07-25-2012, 05:27 PM
Cut/paste from Word into the post edit
Old 07-26-2012, 06:17 PM
Default Thanks for a good paste-ing
Thanks for help I'm better boatman than a user of brains.
20’ Sea Craft Master Angler
1985 Hull
1995 150Hp Evinrude 502 hours
Improvements, starting at the bow.
Pop up nav. Light.
Snag-less SS fairleads for anchor and docking lines
“Starboard” anchor locker hatch
Spare prop mounted on underside if fish box deck
Bilge access hatch in bottom of fish box
Bronze thru hull in fish box, replacing plastic
Engine oil bottle mounted in catch pan
Off season vent hatch to vent fuel compartment
Twin battery hold downs
Master battery switch
Large access hatch in front of console
3/8” windshield
“Starboard” dash panel with tackle pocket and tackle hatch
Light switch in tackle pocket. Will light pocket and inside of console
Tach, temp and voltage gauges
Apelco VHF flush mounted ???
3’ antenna with removable mast. Stainless base.
Lowrance x 75 sounder ???
3 ˝” flush mount compass ???
Sea Star Pro hydraulic steering
Release Marine alloy steering wheel
Hour meter
Circuit Breakers
Fuel tank removed and coated with Interlux Barrier Coat
Bronze thru drain in fuel tank compartment
In tank fuel gauge replaced
Deck hatch to fuel gauge replaced
Bilge access hatch in splash well replaced
“Starboard” door for fuel filter access
One and one half inch bronze thru hulls – cockpit drains to overboard with backflow preventers
Keyless fuel filler cap
Wood trim replaced with plastic moldings
Cockpit sidewall fabric liner replaced with PVC panels
Full canvas winter cover
Fishing related
Schafer sixteen-foot outriggers (never used)
Cannon down riggers
Six rod holders on gunnels
One rod holder on top of console
One ninety-degree rod holder on casting deck
Two rod under gunwale rod storage, each side
Five-rod storage holder on console side with heavy wall tubes
These improvements were done in the late 90’s and some will need to be redone.
Old 09-11-2012, 10:31 AM
Default Still Available
Hey guys I still have this Master Angler for sale, any ideas. Thanks John
Old 09-12-2012, 07:44 PM
red20 red20 is offline
I love the bow cleat "handle"look.
Good luck on the sale. Great boat for the money (regardless of the hull color) I like the yellow BTW.
Looks clean.
Old 05-29-2013, 07:16 AM
She's still for sale, Beaufort NC. area - call - John 252 723 4288
